98 TJ Build....Updated 4/16/10 - Page 20 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2009, 05:26 PM   #381
95geo
newbie
95geo's Avatar
that is the coolest atlas support ring I have ever seen!!! how do I get one? are they available for sale?
Old May 20th, 2009, 06:13 PM   #382
Tab
Tab's Avatar
AA told me not to use any support that comes off the rear output. They said it should be fine alone but if you think you really need a support then to do it off the bottom plate bolts. Theres multiple threads on pirate too about tranny breakage with the use of rear support rings. Just an fyi I suppose. Builds looking good by the way.
Old May 20th, 2009, 06:24 PM   #383
95geo
newbie
95geo's Avatar
the problem with the ones breaking is more a problem of crappy mounting rather than having a tail shaft support.
if you look at almost every one that has had a failure it is because the transmission took an impact and the tail shaft support held the t-case down and something had to give. if you make the trans and it's mount so it's not going to take an impact without distributing it evenly then you will have problems... I.E. different crossmembers for each mount or one of them against the belly skid where it will deflect.
mine will have the mid support, tail shaft support and torque arm off the output side of the t-case mount all on the same cross member, if one takes a hit they all will. that's the key.
if I had more than 1/2" clearance from my t-case to the cross member I would make a single support that hooked to the access panel like AA's divorced mount and BTF's latest mount. the more material you can grab and hold together in one piece the better.
Old May 21st, 2009, 08:24 AM   #384
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
ive seen this and noticed it alot on pirate. Im still on the fence with using some kind of t-case support with my 4speed.
I'm the man in White.
Old May 21st, 2009, 08:24 AM   #385
benny87
Young Gun..!
benny87's Avatar
They are for sale, $65 As is in the picture. I will take some better pictures this weekend. They are CNC'd 6061 .50" Thick, you just have to add a bushing.
Now for my update......
IT LOOKS LIKE A JEEP (somewhat)
The tub is sitting on the rear uppers because I have to still clearance the tub for the rear uppers. So really it has to come down about another 1.0" than it should be good.
benny87 is offline   Reply With Quote
Old May 21st, 2009, 08:27 AM   #386
95geo
newbie
95geo's Avatar
nice looking low rider
Old May 21st, 2009, 08:30 AM   #387
benny87
Young Gun..!
benny87's Avatar
Right there is only 65"s on the 30" spares so add another 5" for 5" rad on the tire and than add another 4" for shock because this is at full pump, so the overall well say will be at 75".. Im happy with that, my full traction lift and my 35s my jeep was 77" to the top of the windshield.
Old June 18th, 2009, 08:53 AM   #388
jeepnfool
Hey guys, I am new here and jumped over from pirate to check out benny's build for the front 4-link (currently building a TJ). Anyways, I wanted to mention something about the rear support on the Atlas. I was debating this and got to talking exstensively to AA about it. The Atlas is not designed to support anything on the tail housing like it will when you add the support there. That is why they tell you to support it from the bottom. Also, the biggest reason I didnt use a tail support is that as soon as you do, it automatically voids your warranty on the atlas.
Anyways, build looks good benny. You need to update this thread also, its been a month..
jeepnfool is offline   Reply With Quote
Old June 18th, 2009, 10:46 AM   #389
95geo
newbie
95geo's Avatar
Ben, throw that POS away, if you put it on you are going to break your shiny t-case.
The only time an atlas breaks from a tail shaft support is because of an impact.
Old June 18th, 2009, 09:58 PM   #390
tom77cj5
tom77cj5's Avatar
how did you get your front brackets at the frame with the uppers turned at a 90* like that?
I'm basically doing the same build you are
with the same frame brackets as the ones on the rear but trying for front and rear on my jeep.
looks good man
Old June 19th, 2009, 07:23 AM   #391
95geo
newbie
95geo's Avatar
http://www.polyperformance.com/shop/...ts-p-1965.html
Old June 19th, 2009, 02:58 PM   #392
tom77cj5
tom77cj5's Avatar
i c modified three link ones
Old June 20th, 2009, 10:56 PM   #393
benny87
Young Gun..!
benny87's Avatar
When you order 3 link mounts they come with the tabs to make it a 4 link.
Old June 29th, 2009, 11:05 PM   #394
tom77cj5
tom77cj5's Avatar
any more updates? who tapped your front uppers for you and what are the upper link lengths your running
I'm having trouble clearing my oil pan and having any chance of a front drive shaft, i didn't notice until now the tapped links that would free up some room for sure
Old June 30th, 2009, 12:22 PM   #395
benny87
Young Gun..!
benny87's Avatar
Well Updates, ya its been all small sheet metal and what not. No real picures. Made some neat looking covers for my air shocks in the rear fenders, bought an art carr shifter today actually. Made a mechanical linkage design here at my work for my atlas instead of cables. Umm working on a design for the center console and what not. Looking at some wiring stuff for the engine and a fuel cell. So just a bunch of little tedious work..
I tapped my upper links, they are for 7/8" Rod ends. I dont remember my tubing thickness, but I had to drill them before I could tap them. I want to say they were OD 1.25" x .25" wall. But dont hold me to it.
For the atlas tail shaft support. It is still in the air on what i am going to do because for simplicity I might be able to make a mount that will support the case from the bottom plate and might be able to get that to work, But its still in the air because I have its small bolts that hold the bottom plate on the tcase and I would be supper mad if I destroyed the threads soo. When i finish the fuel and the interior stuff and wiring I will take the tub off once again and do some more fab work down there.
Old July 14th, 2009, 06:52 AM   #396
cvwindows
I think I can make it!!!!
cvwindows's Avatar
I may be interested in a atlas support also.
cvwindows is offline   Reply With Quote
Old July 14th, 2009, 07:51 AM   #397
benny87
Young Gun..!
benny87's Avatar
Alright let me know, I can get one done maybe Fri, if not first of next week, or I think I might have one left over, so just let me know.
Old July 17th, 2009, 10:18 PM   #398
tom77cj5
tom77cj5's Avatar
hurry up and make your front driveshaft so i can copy it
but really I'm anxious to see how you fit it in because mine is going to be the same dam near
Old July 29th, 2009, 08:17 AM   #399
benny87
Young Gun..!
benny87's Avatar
SO I got some new rubber...
Well there for the 52 Power wagon.. But there NEWWW..
My Iroks are forsale with the H2 wheels. set of $1600.00..
I'm going with a new wheel and tire combo.
Old July 31st, 2009, 08:01 AM   #400
Broncoholic
Guest
Posts: n/a
Dam N=I=C=E Benny where is the Jetz???
Tags
whore ass topedo skank
Page generated in 0.45518 seconds with 84 queries
