98 TJ Build....Updated 4/16/10 - Page 19 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 20th, 2009, 08:05 AM   #361
benny87
Young Gun..!
benny87's Avatar
Originally Posted by 95geo View Post
so have you figured out how you're going to get the ramps out after you put the deck back on?
You under estimate me.... Im sneeky sneeky..
But theres opening on the other side of the frame and there are fish plates and other braces for where I cut open the trailer.
benny87 is offline   Reply With Quote
Old April 20th, 2009, 08:31 AM   #362
95geo
newbie
95geo's Avatar
the last thing I would ever do is cut a main rail on a trailer.... the ramps are added length wise in the deck and across the deck mounted below the rails for a reason.... the only way I woudl even think about that is if the side rails were over 6" tall...
show a picture of where you cut the main rails.... my guess is that it's not strong enough.... do some FEA on a simple cross section of the ramp cutout in the main rail, you will be suprized at what the vertical rail really does.
Old April 20th, 2009, 08:32 AM   #363
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
trailer pro now? sweet
Old April 20th, 2009, 09:11 AM   #364
Broncoholic
Guest
Posts: n/a
It will fold like a paper air plane....
Nice rig ya got goin
Old April 20th, 2009, 09:53 AM   #365
95geo
newbie
95geo's Avatar
and you're still a douche bag, some things change, you cant seem to. at least you fill out the "douche bag cop who got picked on in school" role pretty well.
back to the ignore list for you.
Old April 20th, 2009, 11:13 AM   #366
benny87
Young Gun..!
benny87's Avatar
Well rail is 6in tall and its 3/8" thick than theres a 1/4" fish plate inside and out.. I would agree that if there was constant weight on it it would fail. But both vehicles rear tires are 2 ft in front of the cut out still and I added my 2x4 tube i had left over to place infront of the section I cut out between the left and right rails. The suspension mounts are also 3 feet in front of the cut out so that wont be an issue. So really I think it will be just fine.
Edit:
And maybe I should restate.. I didnt cut a whole section just a "window" 2.5" x 12.5" out of a 6" x .375" stock
Old April 20th, 2009, 11:18 AM   #367
Less trailer, more Jeep
Old April 20th, 2009, 11:22 AM   #368
benny87
Young Gun..!
benny87's Avatar
lol.. Im trying, just gotta get some stuff done with so that I can..
Old April 20th, 2009, 12:37 PM   #369
benny87
Young Gun..!
benny87's Avatar
And for some FEA on the cross section
With Cut out and fish plate.
Factor of saftey: 1.72
Under stress movement max: .5mm
Standard piece:
Factor of saftey: 3.99
Under stress movement max: .46mm
These were under 3500 lb loads because I highly dought I am going to be placing 7000 lbs (trailer max) on this one section of the rail at one time. SO I think it will be fine, I know I am not a engineer but my dad who is and I are both pretty confident that its not going to be an issue. And the factor of saftey means anthing under 1 is failure for those who dont understand that term.
Old April 20th, 2009, 03:42 PM   #370
Mclovin
"The Situation"
Mclovin's Avatar
Standard piece:
if you tow with it.. you will die.. if you think about towing with it.. you will die.. dont do it man !
Old April 21st, 2009, 08:15 AM   #371
benny87
Young Gun..!
benny87's Avatar
First off this is coming from someone who drove their s10 with 2 body mount bolts holding the body to the frame and wheeling the snot out of it.
Next, I think that this trailer holding a 2500 LB jeep wont be an issue when it is 3 Ft away from where the window opening is.. So it will be fine. I am not worried about it. For the price it was worth it.
Old April 21st, 2009, 08:21 AM   #372
95geo
newbie
95geo's Avatar
Next, I think that this trailer holding a 5000 LB jeep will be an issue when it is on top of the window openings and hitting michigan pot holes the size of a tire....
fixed it for you.
Old April 21st, 2009, 08:26 AM   #373
benny87
Young Gun..!
benny87's Avatar
fixed it for you.
Well actually dads convoy doesnt even go through MI... SO its dialed..
Old April 21st, 2009, 03:39 PM   #374
Mclovin
"The Situation"
Mclovin's Avatar
ummmm... There was 2 whole ones left ??
Old May 1st, 2009, 08:57 AM   #375
benny87
Young Gun..!
benny87's Avatar
Default Update 5/1
Alright now that I have almost finished the trailer and the Willies. I got to do some work on mine last night. Although its nothing super huge but it was a step forward. Heres my design for the rear axle shock tabs.
.250" plate at the back that rolls down the axle tube
.150" plate for the front that tie in it into the axle link mount
Old May 15th, 2009, 07:53 AM   #376
benny87
Young Gun..!
benny87's Avatar
Heres what the final product looks like. This is going to OH today for the weekend so I get to finally work on my junk.
Old May 18th, 2009, 08:07 AM   #377
benny87
Young Gun..!
benny87's Avatar
Default Updates
My work from the weekend.
I still need to come up with a design for the upper mounts on the axle mount for gussets so when I do the gears I will do something there.
Old May 20th, 2009, 07:55 AM   #378
benny87
Young Gun..!
benny87's Avatar
Default Another Update
Got the engine in but the exhaust is going to be a fun one so I am trying to plan it out now before I go any further. So that also means I get to bring in the tub tonight and see if I cant find somewhere to place the exhaust.
But heres some pictures.
Old May 20th, 2009, 11:22 AM   #379
4Bangler
Jackstand Wheeler
4Bangler's Avatar
What's the purpose of the 20oz bottle on top of the t-case? Some sort of poor man's level?
Old May 20th, 2009, 12:01 PM   #380
benny87
Young Gun..!
benny87's Avatar
No My buddy was to lazy to throw the bottle in the recycle so he laid it there..
Tags
whore ass topedo skank
Page generated in 0.65648 seconds with 84 queries
