98 TJ Build....Updated 4/16/10 - Page 16 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 26th, 2009, 07:36 AM   #301
95geo
newbie
95geo's Avatar
notch the frame....
I said cut a little at a time from the wheel wells.... not cut everything out and worry about filling it in later!!!!!
Old January 26th, 2009, 07:50 AM   #302
What are you doing at the top of the shock hoops to support them from flexing left/right?
Old January 26th, 2009, 07:54 AM   #303
benny87
Young Gun..!
benny87's Avatar
I tried to cut the least i could. But i want to be able to remove the body off the chassis. I plane to use that big ass sheet of .064" sheet of steel in my garage for making the new panels and i have a bead roller to make it rigid and so on..
So you think to notch the frame.... Im going to have to make some calculations to see how far i need to goo. I tihnk when the link hits the frame i still have under 1.5" of shaft showing. So ill see what amount needs to goo.
benny87 is offline   Reply With Quote
Old January 26th, 2009, 07:56 AM   #304
benny87
Young Gun..!
benny87's Avatar
I am either going to tie it into the cage or run a spreader bar between them. what I am thinking is that I am going to run the spreader bar between and add a removable panel from the bar to the floor and use that as a compartment for straps and stuff than on the other side have the fuel cell and tool storage.
Old January 26th, 2009, 08:02 AM   #305
Add a crossmember and go double triangulated with the rear, or notch the frame Looks good
Old January 26th, 2009, 08:04 AM   #306
benny87
Young Gun..!
benny87's Avatar
ID rather not have to get rid of my frame 4 link mounts. i got the geometry down good.
Old January 26th, 2009, 08:18 AM   #307
95geo
newbie
95geo's Avatar
notch the frame and plate both sides with .120" about 6" on each side of the cutout... the cage will help stiffen it up so you dont have to worry TOO much about the weaker strength of the shorter cross section...
Old January 26th, 2009, 11:03 AM   #308
dodson
dodson's Avatar
looks like a lot of time and thought went into building this. cant wait to see when its done
dodson is offline   Reply With Quote
Old January 26th, 2009, 11:33 AM   #309
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
notch the frame!
http://www.greatlakes4x4.com/showpos...0&postcount=28
nice work.
Old January 26th, 2009, 11:46 AM   #310
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
yeah notch the frame DUH
Old January 26th, 2009, 11:51 AM   #311
benny87
Young Gun..!
benny87's Avatar
Ahhhh thanks for the link..
Old January 26th, 2009, 11:56 AM   #312
TJontherox
Mall Rated
TJontherox's Avatar
Send a message via Yahoo to TJontherox
I would notch the frame. The forces from the suspension are transfered to the link mounts on the frame. You basically need to support the weight of the back half of the rig. With the way it is plated and the addition of the cage tieing it together you shouldn't have any issues.
TJontherox is offline   Reply With Quote
Old January 26th, 2009, 12:21 PM   #313
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Just notch the frame
Old January 26th, 2009, 01:31 PM   #314
STOOOOP! DON'T NOTCH THE FRAME!
Just cut a whole section out instead. You don't really need it.
Old January 26th, 2009, 01:48 PM   #315
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
just bend the arms.....:hehe:
nate4d is offline   Reply With Quote
Old February 6th, 2009, 08:10 AM   #316
benny87
Young Gun..!
benny87's Avatar
Okay had some good/bad news yesterday...
Good: Got my ballistic diff covers
Bad:
In the pictures you will see the body mounts. the 2 front most are ok just need a tap ran threw the mounts. The far most rear (back half section) mounts for the body are ok.
ALL the rest only 4, are broken. 1 spun the nut inside the body mount the other rusted the ENTIRE sheet metal away so that when i tried taking off the bolt it spun all around with the SHEET METAL PART OF THE BODY...ie- broken body mounts..Ohhh and to add I built my tube fenders for my ganster lean body so now those are garbage. SWEEET
SO to fix this small problem i have a few options.
A) Buy a new/ southern used tub....Like this idea
B) Try to patch the holes and run it
C) Use the existing tub and mount it correct to the frame with the good mounts and make new mounts with a better/ more easlily repairable mounting setup.. (take a peice of 1/8in plate along the channel for the body mounts and do a cage tie instyle mount).
All of these ideas will have to include new front fenders which im thinking of doing this..
Old February 6th, 2009, 08:51 PM   #317
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
I say repair the body your planning on beating the crap out of it anyway.... I even have a plasma cutter to sell you to help with the job too. I will be posting it for sale next week. Would even work out a trade for those 39.5" tires you got there....
NitzPixs is offline   Reply With Quote
Old February 6th, 2009, 09:02 PM   #318
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
How much for messed up tube fenders?
Old February 6th, 2009, 09:40 PM   #319
hosejockey4506
Visiting Admin
how much for junk tub ?
Old February 7th, 2009, 01:33 PM   #320
Mclovin
"The Situation"
Mclovin's Avatar
idea C
Tags
whore ass topedo skank
Page generated in 0.38182 seconds with 84 queries
