98 TJ Build....Updated 4/16/10 - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 28th, 2008, 03:35 PM   #221
benny87
Young Gun..!
benny87's Avatar
Got ya, just wondering
benny87 is offline   Reply With Quote
Old November 28th, 2008, 04:26 PM   #222
bbaXJ
Yooper In Training
bbaXJ's Avatar
Originally Posted by 95geo View Post
you dont need it.... you would need to have 400+ hp to start thinking about a 4l80 and they dont come behind the engines you are looking at. a mildly built up 4l60 will handle the hp that you'll be making after some mods on that engine. once you break 500hp then start thinking about a bigger, built up trans.... for now mild mods to the 4l60 will handle all you can afford to throw at it after making more hp... stock for stock, they work great together and some calibrations will get you the shift kit feeling.
That's really pushing it based on my experiences. I've got several buddies who've broken a handful of 4L60Es, both stock and built, behind fairly mild gen III smallblocks. I've seen some hold up to more abuse than you'd ever expect, others have sh1t themselves way more easily than a trans ever should. Hell, one buddy has killed 3 or 4 of them in a bone stock 96 Silverado. One even twisted off an output shaft behind a mildly modded 6.0. It seems to be pretty hit or miss whether or not they'll stand up to the abuse....
That being said, I'm giving it a shot. I've got a 700R4 that's supposedly got about $2k worth of work done to it that I'll be running behind my mildly built 6.0. I'm gonna have a full manual reverse pattern valvebody with compression braking, torque converter lockup switch, and a big trans cooler. I'll definitely be putting it to the test but hopefully it'll hold up.
Old November 30th, 2008, 05:32 PM   #223
benny87
Young Gun..!
benny87's Avatar
Well i think im just going to do a 5.3L. and do some mods to it but nothing bigger. SO if anyone has a 5.3L from 02-05 PM me.
Old November 30th, 2008, 07:19 PM   #224
bbaXJ
Yooper In Training
bbaXJ's Avatar
Why 02-05?
Old November 30th, 2008, 07:45 PM   #225
Mclovin
"The Situation"
Mclovin's Avatar
My Dad's got an 05' 5.3 GMC...
but its in his truck
Old December 1st, 2008, 06:40 AM   #226
benny87
Young Gun..!
benny87's Avatar
Thanks andy how much...
I was told thats the perferred years, better design and system.
Old December 1st, 2008, 06:41 AM   #227
benny87
Young Gun..!
benny87's Avatar
Also, sean do you still have a 4l60e that if i convinced you enough i can possibly borrow for some mock up mounts and so on..
Old December 1st, 2008, 08:54 AM   #228
95geo
newbie
95geo's Avatar
Ben gets a little carried away when you tell him something....
I told him to stay away from the earlier ones, not that there are problems with them but the later ones have some of the better redesigned parts and things like that. The newer ones are too expensive for the most part. the only benefit to the older ones is the cable throttle is easier to come by but that can be taken care of easily enough with an aftermarket TB.
an E85 engine would be nice because you get an oversized fuel system and the injectors will support big HP on a short spray duration without having to swap them out. the AFM would also make for a pretty cool feature.... cruising around, flick the switch and you're in 4 cyl mode, flick it back and you're 400+ hp. not needed but would be a cool feature!
Old December 1st, 2008, 09:08 PM   #229
Mclovin
"The Situation"
Mclovin's Avatar
i duno he's kinda attatched.. but ill bet i could pry it from him for around 15k ish
Old December 1st, 2008, 09:59 PM   #230
bbaXJ
Yooper In Training
bbaXJ's Avatar
Mine's a 700R4 but the case and stuff should be the same. I've got a spare but currently it's in the rig for mockup.....how soon would you need it?
Old December 2nd, 2008, 06:44 AM   #231
benny87
Young Gun..!
benny87's Avatar
Like a 3-4 weeks.. id start mocking it up, I first have to clean it up and paint some misc parts on the engine if needed. and install some power adders...
Old December 2nd, 2008, 08:09 AM   #232
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
or something to get wet muddy and fail
Old December 2nd, 2008, 10:33 AM   #233
benny87
Young Gun..!
benny87's Avatar
No more mudd unless its just touching the rim no mounds bogg fest for this when its done. lol
Old December 2nd, 2008, 10:42 AM   #234
95geo
newbie
95geo's Avatar
how often does a factory ECM fail? how about the lifters?
you'd better tell everyone with cam phasing and active fuel management that their engine is going to fail when they least expect it.... about 70% of current vehicles being sold has one if not both of those features on it.
quit worrying
Old December 2nd, 2008, 11:17 AM   #235
bbaXJ
Yooper In Training
bbaXJ's Avatar
I'll see what I can do. If I get the rear suspension done quickly then maybe I'll get a move on my engine stuff so I can do the swap. I've got a lot to do and that part wasn't particularly high on my priority list for now.
Old December 2nd, 2008, 11:21 AM   #236
95geo
newbie
95geo's Avatar
I have a 700r4 he can borrow.
I'm trying to talk him into just picking up a junk one off craigslist for mock up and a spare.
Old December 2nd, 2008, 11:44 AM   #237
benny87
Young Gun..!
benny87's Avatar
i found some.. thanks
And a tcase... hummmmmmmmmmmmm
Old December 2nd, 2008, 05:25 PM   #238
bbaXJ
Yooper In Training
bbaXJ's Avatar
Good stuff. That's what I did too. I picked up a TCI built one on here for cheap then a buddy hooked me up with one that has a ton of work done to it for just as cheap. If I break one I've got a spare and if I break both it's time to upgrade. Sh1tty part is that the valvebody is gonna cost more than both trannies combined.
Old December 3rd, 2008, 06:50 AM   #239
benny87
Young Gun..!
benny87's Avatar
Ya i found one off criagslist that i might snag for 50 bucks.
Old December 5th, 2008, 07:10 AM   #240
benny87
Young Gun..!
benny87's Avatar
And heres another new addition to the Jeep build.
5.3L I got a 1 yr warrenty for the block and internals and a 2 yr warrenty for all the accesories. 66K miles And i got all the peddle stuff with it aswell.
Tags
whore ass topedo skank
Page generated in 0.31990 seconds with 84 queries
