Garage clean-out: CJ parts - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 19th, 2006, 03:41 PM   #1
BATLWGN
BATLWGN's Avatar
Default Garage clean-out: CJ parts
Some stuff that has been sitting in my garage and it is time to get it out. Parts were in a 78 CJ7:
Dana 30 Front and AMC 20 rear already set up for SOA. $75 a piece
Fuel tank - $20
Tilt Steering column, needs lower bearing - $30
Rear swing out tire carrier - $20
Power steering gear box, no leaks - $30
Power steering shaft (the one between the column and gear box) - $30
Bare grille section, slightly tweaked but will straighten when bolted up - $20
stock dash with main gauge cluster, dash needs some TLC - $20
rear fender flares - $20
tinted glass set out of a hardtop, with seals - $20
All prices are OBO.
BATLWGN is offline   Reply With Quote
Old April 19th, 2006, 05:03 PM   #2
sandmaster
sandmaster's Avatar
damn was in otesgo today but will be there next week would like the tilt column if its avaliable still
sandmaster is offline   Reply With Quote
Old April 20th, 2006, 08:50 AM   #3
BATLWGN
BATLWGN's Avatar
Let me know when
Old April 20th, 2006, 05:07 PM   #4
Blackbeast2
Hardcore since 84
Dose the tank leak or any thing? also were in the world is Otsego?
Blackbeast2 is offline   Reply With Quote
Old April 20th, 2006, 06:18 PM   #5
Arnie897
y=mx+b
Arnie897's Avatar
Send a message via AIM to Arnie897
I will take 1 power steering gear box. Delivery available to a local auto zone?
Arnie897 is offline   Reply With Quote
Old April 20th, 2006, 06:36 PM   #6
tonka5
tonka5's Avatar
Send a message via Yahoo to tonka5
what kind of tlc does the dash need?
tonka5 is offline   Reply With Quote
Old April 20th, 2006, 07:55 PM   #7
sandmaster
sandmaster's Avatar
will be there next week does one day work better than a nother and what time works for you and an address where i can pick it up . thanks randy
Old April 21st, 2006, 12:13 AM   #8
BATLWGN
BATLWGN's Avatar
Tank does not leak.. Otsego is about 20 minutes north of Kalamazoo.
Sure Mike, I will get the box to AZ ...just gotta pull the pitman arm off.
The dash.... the screw holes where the dashpad was attached had surface rust around them. I started to refinish it and didn't get very far. I was going to do some fiberglass repair to fill the holes and sand it smooth. It is salvageable. I will try and get some pics tomorrow night.
As far as what day, I have a fairly flexible schedule next week, let me know if there is a time best for you. I will probably take Wednesday off.
Old April 21st, 2006, 03:16 AM   #9
Arnie897
y=mx+b
Arnie897's Avatar
Thanks Eric....just PM me when you find time to bring in down.
Old April 24th, 2006, 10:17 PM   #10
BATLWGN
BATLWGN's Avatar
bump.
Page generated in 0.21250 seconds with 53 queries
