86 cj 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2008, 08:59 PM   #1
ktc
Default 86 cj 7
Engine.
258 p.s p.b auto,offi intake, 390holley,borla s.s. header and exaust, h.o. (200amp?) alternator, msd ignition, electric fuel pump, trans cooler, oil cooler.
Suspension and driveline.
3.5?/1 gears 2.73 extra, 44 rear 30 front power trax in both,(3"?) warn black diamond lift,shackels reversed, heavy duty shackels, ubolt skid plates, rear cardan joint and degree wedges, sway bar disconnect, drop pitman and sway mounts, steering box brace, poly bushings.
Body and the rest.
All fiberglass, soft top and bikini, rollbar tied to frame, wide fender skirts, nerf bars, rci buckets, poly tank, s.s fuel trans and brake lines, all hardware(hinges, brackets, bolts...) s.s. warn 4000#winch,marine radio, 55/100 hella head lamps, some extra parts from the rebuild about 8yrs ago, there is probably somthing I am forgetting. Would like to get 7500$ but would consider any reasonable offer. Thanks for looking!
ktc is offline
Old July 11th, 2008, 05:06 PM   #2
ktc
Any guesstimates if im in the ball park on the price?
ktc is offline
Old July 11th, 2008, 05:17 PM   #3
boggin-machine
boggin-machine's Avatar
id guess a little high since most people will rip out the axles and tires and eather link it and 1 tons and go alot bigger.
but best of luck to you.
boggin-machine is offline
Old July 14th, 2008, 05:10 PM   #4
ktc
Thanks for the reply!, maybe 5500$ ?
ktc is offline
Old July 18th, 2008, 05:04 PM   #5
ktc
5000$obo.
ktc is offline
Old July 18th, 2008, 05:40 PM   #6
Fraser
Fraser's Avatar
that isnt always true, bump for ya
Fraser is offline
Old July 21st, 2008, 06:15 PM   #7
ktc
Also has tow bar I will include
ktc is offline
Old July 29th, 2008, 09:39 AM   #8
ktc
++++sold!
ktc is offline
Page generated in 0.19742 seconds with 47 queries
