Motor problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2008, 05:47 PM   #1
87'YJ
Jeeps, Journey and Jesus
87'YJ's Avatar
Default Motor problems
Had the boat out yesterday and it ran great for about an hour then all of a sudden, started sounding deeper and couldn't get the rpms up. Couldn't get the boat on plane.
Pulled the cover and everything looked fine, then saw this. Not sure if this is just a ventilator/breather line, but I hadn't seen it before. Comes out of the bottom of the engine block. What is this supposed to run to? Its a Johnson 225HO btw.
The power surged back on/off a couple of times leading me to believe that there may be some faulty electronics as well. Just wanted to post here before I start digging into it.
87'YJ is offline   Reply With Quote
Old July 10th, 2008, 08:18 PM   #2
92comanche4x4
92comanche4x4's Avatar
could it be for oil ?
92comanche4x4 is offline   Reply With Quote
Old July 10th, 2008, 08:29 PM   #3
max5p33d
slack jawed faggot
max5p33d's Avatar
Send a message via ICQ to max5p33d Send a message via AIM to max5p33d Send a message via Yahoo to max5p33d
Looks and sounds like oil to me.
max5p33d is offline   Reply With Quote
Old July 10th, 2008, 09:40 PM   #4
87'YJ
87'YJ's Avatar
Nope its the crankcase ventilation hose and it plugs into the aircleaner at the top. Someone on another board helped out with it. Hopefully that plus checking all of the electrical connections will stop the problem.
Old July 10th, 2008, 09:49 PM   #5
Bow_Extreme
Bow_Extreme's Avatar
I don't think a crankcase breather hose would cause that. You just get an oil residue in the immediate area. Fuel problem? plugged filter? Fuel pump?
Bow_Extreme is offline   Reply With Quote
Old July 10th, 2008, 10:41 PM   #6
kickstand
circling the drain
kickstand's Avatar
sounds like possible fuel or stator/el;ectronics
kickstand is online now   Reply With Quote
Old July 11th, 2008, 03:06 AM   #7
87'YJ
87'YJ's Avatar
Agreed. Its not a fuel issue as I have that all worked out and this feels very different. i'm leaning towards electrical and I need to take it on another test run as I believe after reconnecting all of the wires, etc its running right.
Page generated in 0.26323 seconds with 44 queries
