tf727 kickdown rod/cable.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2008, 01:41 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default tf727 kickdown rod/cable....
I'm guessing this is needed as I know it applies pressure to when you shift.
Since I put a TBI on my motor the rod dosn't work so well. I do not have the funds for a lokar cable at the moment....
Currently its not hooked up at all or even wired half engaged. I'm sure this will hurt the trans if left like this for a long time???
Should I just wire it 1/4 shut? 1/2 shut?
Old July 10th, 2008, 04:54 PM   #2
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Plato,
I have a 727 also, and I wouldn't wire it up like that if I were you. It has to build pressure as you increase throttle to shift. You could try it but I don't think it is going to work.
What is the Lokar cable going to do that the OEM linkage can't?
Old July 10th, 2008, 06:47 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Its easier to adapt and doesn't require space for that arm to swing. Currently without it hooked up I can shift the trans into any gear at any rpm (which i love!).
Old July 10th, 2008, 07:14 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
get the cable...
Old July 10th, 2008, 07:23 PM   #5
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
hey just the man I was hoping for.... So do I run risk of hurting the trans without anything hooked to it??? Also could you explain why, or point me to a link. I cannot find anything
Old July 10th, 2008, 07:30 PM   #6
84ramcharger
sim sim balla bim
84ramcharger's Avatar
I have a new one that I bought for my 727 in my ramcharger that I never opened or used. Let me know if you are interested I will take a picture of it or give you the numbers off it and you can see if it will work. I do not see why it wouldn't but it's better to double check.
84ramcharger is offline   Reply With Quote
Old July 10th, 2008, 08:57 PM   #7
ppkaprince98
Size Matters (.)(.)
When I bought my 727 the guy I bought it from made sure I had the linkage and showed my how to hook it up correctly like it was absolutely necessary!!!! I have been told by others that the life of your trans will be short lived without it. I have the Lokar also for fit reasons, but I would not run it too long without the linkage.
My $.02
Here is a link from Hot Rod magazine.
http://www.hotrod.com/techarticles/m...n_linkage.html
Old July 10th, 2008, 11:31 PM   #8
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
84ram: I'm not looking to buy a cable at the moment. If anything I'll get the rod to work.
prince: I do not plan to run it long without it as I to have read it shortens the life. I just thought I would ask on here and double check to see if my findings were correct. Cool article!
Old July 10th, 2008, 11:34 PM   #9
snocross2xtremes
snocross2xtremes's Avatar
i ran my 727 wired 3/4 of the way back and never had a problem.. other then it would shift in to second a little early but i usally had enough power to where it didnt matter
Old July 11th, 2008, 12:18 AM   #10
KILLER"B"468
Yankabilly
You could hurt it by not getting enough pressure in high rpm ranges. the bad is that it may not down shift and you start off in a higher gear causing the forward clutch to work overtime. Like slipping a clutch in a manual car.
With it wired 3/4 to full won't hurt anything but reverse. it will bang into reverse and being on the street with no forgiveness. You could blow the rear strut for the rear band. Or take out the sprag.
Old July 11th, 2008, 12:53 AM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Could I wire it 1/2 shut... or will that still be to much pressure for R? I'm going to do it the correct way, but I just would like to drive it around and get my air/fuel tuned.
Old July 11th, 2008, 01:02 PM   #12
Tom
Because racecar
Tom's Avatar
KillerB is correct. Why risk hurting the trans? You can find all of the brackets and a cable at a pick a part off a dakota, ram or van from the late 80s to early 90s. i believe the V6 TBI brackets are the same also.
Old July 12th, 2008, 07:43 PM   #13
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
i'm just going to be ordering the lokar kit. Thanks guys.
Page generated in 0.24542 seconds with 62 queries
