Edelbrock 1404 Rich - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2008, 12:10 PM   #1
88mudder
In the band!
Default Edelbrock 1404 Rich
I have a new 4bbl 1404 model number, 500cfm carb and its running rich. The engine is a stock 302 except for a 4bbl performer manifold and the carb. The engine runs decent but the plugs are still black. I cant get the engine up to WOT, maxes out at about 4k rpm, but it idles like a top. The engine just revs up slow. Checked the fuel pressure and its right at 6psi. Anybody reccommend anything to make it run leaner?
Old July 10th, 2008, 05:19 PM   #2
88mudder
In the band!
i have a calibration kit on order so ill play with the new jets and metering rods.
Old July 10th, 2008, 05:33 PM   #3
chizzel21
SWAMPBUCKS OFFROAD
chizzel21's Avatar
the mixture screws on the front all the way in 1 and 1/4 turns out for starters
chizzel21 is offline   Reply With Quote
Old July 10th, 2008, 06:14 PM   #4
88mudder
In the band!
yep thx for the tip, it seems to wanna run best at 1 1/2 turns out. Anything less it will die.
Old July 11th, 2008, 04:24 PM   #5
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
Get a vaccum gauge and tune it until you get the best vaccum without stumbling while opening the throttle.
I would look around the web to see what combo metering rods people are using on your size engine, not to mention teh metering rod spec of fuel flow.
mooseracing is offline   Reply With Quote
Old July 12th, 2008, 08:07 AM   #6
04 EDGE
Floor Shift Maddness!
04 EDGE's Avatar
did you put the distributor in right when you changed the intake?
sounds like its a tooth off.
Old July 12th, 2008, 09:27 AM   #7
88mudder
In the band!
that was my first impression. I myself, dad, and Kodiak450r checked to make sure its in right and it is. Gonna try to lean the carb out so the plugs arent black..and set my idle with a vac gauge and go from there.
Old July 12th, 2008, 07:18 PM   #8
88mudder
In the band!
nvm that question..figured it out.
Old July 12th, 2008, 08:53 PM   #9
88mudder
In the band!
Once my tuning kit arrives i will get down to work. Carb is coming off. Removing the 4 main jets and gonna experiement Rich and Lean..as well as the Metering rods. Last thing ill do is check my float height.
Page generated in 0.22959 seconds with 50 queries
