drive train options for 89 ranger - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2008, 09:29 AM   #1
MichiganLarry
A pirate 200 yrs to late
MichiganLarry's Avatar
Default drive train options for 89 ranger
My son has a 1989 Ranger 2wd with an really nice body. We are considering converting to 4wd and I was wondering what my drive train opions are. I was thinking that the easiest thing to do would be to find another ranger with 4x4 and just swap that drive train into his. Am I on the right track or should I be thinking along different lines. The truck currently has a 2.9 with an automatic. I have a few axle combos from my cj-7 that I could also use.
Thanks for any input.
Larry
MichiganLarry is offline   Reply With Quote
Old July 10th, 2008, 09:34 AM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Maybe Ford tech would be better?
Cj axles would be the wrong side to use a ford t case.
4x4 parts would be easier
Old July 10th, 2008, 09:35 AM   #3
your in the jeep tech section lol
but anyways, some will just simply take the whole TTB out from under another truck and bolt it into a 2wd truck. But you cannot do this on a 2wd ranger the engine crossmember is different. As far as ease a Jeep D30 would work being it matches the rear axles bolt pattern.
or you could do a early bronco 44 but the bolt pattern is different stock.
all kinds of fun info
http://www.therangerstation.com/tech_library/index.php
Old July 10th, 2008, 09:38 AM   #4
MichiganLarry
Sorry guys. My bad
Could someone please move this.
Thanks
Old July 14th, 2008, 09:45 PM   #5
jeepxj2007
Send a message via AIM to jeepxj2007
go to therangerstation.com and go to their forums and search for this, there is a lot of info about it, as far as an axle a jeep dana 30 would work, about the same width, same bolt pattern for rims, and the diff is on the correct side. If I can find my petersons issue, there is an article that they did this to a ranger.
jeepxj2007 is offline   Reply With Quote
Old July 15th, 2008, 12:17 AM   #6
booblinker
Sore and Tired 24/7
booblinker's Avatar
I Would find a dana 35 ttb and use and 8.8 rear, 1354(i think) manual t-case. but yea trs is an awesome site for Rangers.
Old July 15th, 2008, 06:23 AM   #7
MichiganLarry
Thanks for the replies. I will check out the ranger station. Would love to see that peterson issue also.
Larry
Old July 15th, 2008, 06:45 AM   #8
in order to put a ttb underneath a 2wd ranger he would have to change the enigne crossmember
Page generated in 0.20582 seconds with 47 queries
