Checking codes on pickup? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2008, 09:21 PM   #1
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
Default Checking codes on pickup?
i have a check engine light on on my 89 pickup. now there is supposed to be a way to jump a wire to get it to blink and get codes. but i am not sure how. anyone help me out? also were to look up codes.
hman1991 is offline   Reply With Quote
Old July 15th, 2008, 06:02 PM   #2
darkteg94
darkteg94's Avatar
Don't make me come over there and show you how to work on my old truck. XD
http://www.greatlakes4x4.com/showthread.php?t=36651
It's codes 21 & 42 last time I checked......o2 sensor and speed sensor. Have at it buddy.
darkteg94 is offline   Reply With Quote
Old July 15th, 2008, 06:17 PM   #3
blownexploder94
Todd
blownexploder94's Avatar
find the 12 pin test connector and you have to connect pin A "ground" to pin B "test terminal" Count flashes It will look like this terminal wise
F E D C B A
G H J K L M thats the 12 pins in the connector on a GM
Old July 15th, 2008, 09:12 PM   #4
hman1991
hman1991's Avatar
i found a good writeup on here http://www.troublecodes.net/Toyota/ and it is only o2 but it was runnin bad now but think i have tracked problem to plugged injectors.
Old July 16th, 2008, 12:07 AM   #5
darkteg94
darkteg94's Avatar
Get er done. That thing was made to wheel.
Old July 20th, 2008, 06:22 AM   #6
Rattler
Home Sweet Homicide
Rattler's Avatar
If it has a bad O2 sensor, I was told you can pull them out (if you can get it out), burn alll the crap off it with a propane torch and you will be good to go. THey aren't cheap. I found out about this trick after paying @ $100 for one.
Page generated in 0.27275 seconds with 41 queries
