Turbo 350 shifting out of 3rd when gets warm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2008, 07:34 PM   #1
PHATS79
PHATS79's Avatar
Default Turbo 350 shifting out of 3rd when gets warm
I have a 79 chevy truck with a 454 built to a 468 with a turbo 350 and np 208 tc. it shifts prefectly fine when cold. when tranny gets to operating temp it takes a lot longer to shift into third gear. and when it finally does i will be driving and at random times it will just downshift into second. i will shift into neutral (while going dow the road still) and shift back into drive and it will be in third, then a few minutes later it will do it again. it slowly gets worse the longer i drive it. i dont know if it has something to do with the modulator, i dont know much about trannys. the kickdown cable is adjusted correctly. i do have an aftermarket cooler in front of the radiator, and yes the tranny fluid is right at the top of the full mark. any ideas?!?!?!
PHATS79 is offline   Reply With Quote
Old July 10th, 2008, 02:03 AM   #2
muddin_wolverine
muddin_wolverine's Avatar
AH. my truck does this too. exactly the same. i just plan on rebuilding it when i get back to the states. ideas would be great! im afraid im gonna tear it down and the broken part doesnt come in the rebuild kit. its my dd
muddin_wolverine is offline   Reply With Quote
Old July 10th, 2008, 05:31 PM   #3
PHATS79
PHATS79's Avatar
ya i think im just gonna rebuild it and get it done with. i was just wishing it was something stupid and cheap!!!
Old July 10th, 2008, 11:20 PM   #4
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
sounds like the3 direct drum has a lot of ring wear.
Old July 15th, 2008, 04:01 PM   #5
PHATS79
PHATS79's Avatar
so you think it needs to be rebuilt?
Old July 15th, 2008, 05:26 PM   #6
KILLER"B"468
Yankabilly
It may only need a set of teflon rings. I don't know if it needs rebuilt. What I can tell you is that 90% of the trannies, I do go into that are used just for a simple fix... could use a freshen up.
Old July 16th, 2008, 11:44 AM   #7
PHATS79
PHATS79's Avatar
alright, i will tear it apart and take a look at it when i get some extra time, thanks a lot!
Page generated in 0.20813 seconds with 44 queries
