Removing carbon from piston during rebuild - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2008, 04:34 PM   #1
booblinker
Sore and Tired 24/7
booblinker's Avatar
Default Removing carbon from piston during rebuild
I am rebuilding a motor, and would like to remove the carbon from the pistons before i put it back together. What is the best way to remove the carbon?
Old July 9th, 2008, 04:36 PM   #2
Chip Wheeler
Chip Wheeler's Avatar
carb cleaner and elbow grease should work good.
Chip Wheeler is offline   Reply With Quote
Old July 9th, 2008, 06:15 PM   #3
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I suggest carb cleaner, but you can also try toilot bowl cleaner. just use enough to submerge the ring lands. DO NOT get it in the piston pin or in between the rings. its just strong enough to remove a couple layers of metal if it get in places you can't wash it out. easy off oven cleaner works to. only let it sit for 3-5 minutes.
Yetti
Old July 9th, 2008, 07:48 PM   #4
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
x2 on oven cleaner
beaterk5 is offline   Reply With Quote
Old July 9th, 2008, 10:36 PM   #5
2kids=nojeepmoney
get a spray bottle with some water and mist it with water. let it sit for a while and it will start to peel off. won't come perfectly clean, but why bother?
2kids=nojeepmoney is offline   Reply With Quote
Old July 10th, 2008, 01:38 PM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I've used purple power.... but DO NOT leave it in their long and dilute it!! I left some pistons in overnight and yeah they were no good after that. Good thing I was buying new pistons
Old July 10th, 2008, 01:47 PM   #7
zjjamie
zjjamie's Avatar
Originally Posted by beaterk5 View Post
x2 on oven cleaner
x3
zjjamie is offline   Reply With Quote
Old July 10th, 2008, 01:57 PM   #8
boggin-machine
boggin-machine's Avatar
how are you rebuilding it if your putting the old pistons back into it? are you just freshing it up? new rings and seals?
Old July 10th, 2008, 02:07 PM   #9
booblinker
Sore and Tired 24/7
booblinker's Avatar
I bought 2 new pistons, was gonna use 2 old ones that weren't damaged. I just ordered another 2 new ones, decided I should just replace them all, plus the one wrist pin is squeaky.
Page generated in 0.28771 seconds with 50 queries
