SOLD - WT C20 2.72 rear with 1-pc shafts - $150 or $100 for shafts only - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2008, 10:05 AM   #1
PavementPounder
PavementPounder's Avatar
Arrow SOLD - WT C20 2.72 rear with 1-pc shafts - $150 or $100 for shafts only
Was replaced with another axle that had better gearing. The passenger side outer bearing was also going bad. You're basically buying the shafts (unknown brand, not Moser) and can get a couple bucks back on the scrap weight unless you want to keep the housing for a spare.
Axle is complete. Leaks from the ends, as it appears that the clown that put it together doubled up the seals. I suspect that the bearings were not pressed on quite as far as they should have been, which is why the leak/double seal thing was going on and probably what led to the passenger side bearing going bad. Was daily driven up until the bearing noise was detected. Comes with all the drum hardware, also.
$150, or $100 for just the shafts.
SOLD.
PavementPounder is offline
Old September 4th, 2008, 10:22 AM   #2
PavementPounder
Bump.
Old September 9th, 2008, 11:49 PM   #3
PavementPounder
SOLD.
Page generated in 0.24076 seconds with 32 queries
