Suzuki 1.3 to a 1.6 HELP!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 7th, 2008, 09:35 PM   #1
monster toy
Northwest Ohio Crawlers
monster toy's Avatar
Default Suzuki 1.3 to a 1.6 HELP!!!
I have an '87 Suzuki with a 1.3 carborated motor and I have a '91 Geo Tracker 1.6 fuel injected 2 wheel drive, does anyone have any tricks or tips on the wiring harness or fuel pump to make the switch over easy?
monster toy is offline   Reply With Quote
Old July 9th, 2008, 08:08 AM   #2
jimmyroyse
webwheeler
jimmyroyse's Avatar
is the tacker an 8-valve or 16-valve?
trailtough.com has everything for this swap.
or try searching at zuwharrie.com.
look for;
- zor sidedraft kit
- f150 fuel pump
- tracker fuel pump
- 1.6 swap
their are a few there who will modify the wiring harness. I can't remember who thou.
jimmyroyse is offline   Reply With Quote
Old July 14th, 2008, 06:37 AM   #3
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
you can run the 1.3 intake and carb till you get ready to do the efi. just get a f150 fuel pump or any elect low psi fuel pump for cared motors. there are mount kits out there. just make sure they come with the special bolts. because they r like $25 the intake will only work with the 8v motor though.
hman1991 is offline   Reply With Quote
Old July 14th, 2008, 07:22 AM   #4
KartRacer
Blowd up
KartRacer's Avatar
That is a good option, or you can use the 1.3 head and stock fuel pump.
What direction are you wanting to go with this?
Old March 12th, 2009, 01:01 AM   #5
jeepman784
Now pedals a bicycle
jeepman784's Avatar
Send a message via AIM to jeepman784
what did you do with the wire harness?
jeepman784 is offline   Reply With Quote
Old March 12th, 2009, 04:43 PM   #6
A4X4SPIT
A4X4SPIT's Avatar
Ive done several 1.6 swaps(doin one now) all but the current one I used fi the 16v's mfi & the 8v's tbi I use the tracker fuel pump ontop of the sami gas tank there a spot thats perfect for mtg the fuel pump just cut a hole & install the mtg plate w/self taping screws and seal it good w/some sealant (seal all)
Ive done all my own wiring & basically you get the whole wiring harness from doner car leave the engine harness alone & start getting rid of all wires that dont go to the computer(ecm) , relays,the engine harness, grounds or power sorces get a chiltons book & find the page with the pin #s on the ecm& the right wiring diagram for doner car lay out harness start labeling & cutting you will end up with several switched power wires some power on always(battry + )ground wires a diagnostic plug or some cut wires if you dont need it (Ive done it both ways &never used the plug) acouple relays a wire from one relay goes to fuel pump hot .use the sami starterwires /charging systems a wire off ecm is for a tach .you can get sami temp wire to tracker temp senser. Ive done somwe that I left fuse'sfrom tracker in the loop
its just time consuming checking wire colors & pin #s & double checkin with the wiring diagram I set it up on a sheet of osb board & cut all the tape off used some screws to hold it in place if you can figure out how to get a 1.6 into a sami you probably could figureout wiring
A4X4SPIT is offline   Reply With Quote
Page generated in 0.22414 seconds with 41 queries
