KX 125 using trans fluid. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2008, 10:13 PM   #1
stevelknievel
Fuck Cancer
stevelknievel's Avatar
Send a message via AIM to stevelknievel
Default KX 125 using trans fluid.
my 93 kx 125 has been losing a little bit of trans fluid. it doesnt seem to be dripping any either
and i read that this guy used regular ATF in his trans, if i decided to use the reg. stuff instead of the bel ray stuff is it gonna cook the clutch or damage the trans?
stevelknievel is offline   Reply With Quote
Old July 6th, 2008, 10:54 PM   #2
jeepguy74
jeepguy74's Avatar
dont do it!! just use the stuff that is recomended .....
i would guess that you have a case seal leaking anf it is just burning it in the motor...i have seen this happen and you wouldnt know it if you didnt see the level going down......
Old July 6th, 2008, 11:08 PM   #3
stevelknievel
Fuck Cancer
yeah i think it may be a crank seal it uses so little i think im gonna give it a leakdown test eventually
and over on thumpertalk they said that alot of guys use the reg stuff in the kawie 2 strokes. im not quite out of my bel ray stuff but at 10 bucks a quart i might try it lol
Old July 6th, 2008, 11:26 PM   #4
88mudder
In the band!
deffinetly a seal inside the engine, the fluid is being burnt through the pipes..
Old July 19th, 2008, 10:04 PM   #5
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Dude.
Use type F trans fluid. I have run it for years and have had no troubles. Throw a few oz. of brake fluid in with your next change (yes, brake fluid). The brake fluid may swell the seals for awhile until you can swap them out (kawis need the case split to change them out - I have the tools you need to do it).
@clarkstoncracker
Old July 19th, 2008, 10:36 PM   #6
stevelknievel
Fuck Cancer
Dude.
thats what ive been using. it doesnt use much at all. and ill have to try the brake fluid!
and i dont plan on tearing the motor apart til it blows or winter. but when i do ill get in touch
thanks man!
Old July 19th, 2008, 10:42 PM   #7
wildpig
DONUT LOVER
wildpig's Avatar
Originally Posted by jeepguy74 View Post
dont do it!! just use the stuff that is recomended ..... X2 except add a bit of break fluid as mentioned. It should seal the leak if it's not real bad. At least till the rebuild anyway....
X2
wildpig is offline   Reply With Quote
Old July 19th, 2008, 10:57 PM   #8
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
thanks man!
My pleasure - tools are expensive; no reason to buy them if I can borrow them to you.
@clarkstoncracker
Old August 1st, 2008, 07:32 AM   #9
smasheromalley
smasheromalley's Avatar
I have an 85 kx125 and use typeF in it as well. No problems in the 4 years Ive been running it.
Page generated in 0.27402 seconds with 50 queries
