Got an issue with my 4.3 Mercruiser... Can you help? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 6th, 2008, 07:40 PM   #1
Covert_Ops
Default Got an issue with my 4.3 Mercruiser... Can you help?
So we were stranded in the boat today...
This has happened before and I have to tell you I was ready to sink the thing... Seriously it has happend the last 5 times we have had the boat out.
So we set out for a day of boating... Drive about 20 min. through the halfmoon chain, shut down do some fishing etc. Try and start it and nothing... I mean nothing. All the gagues power up the alarm sounds (to let you know it is working), but nothing. Then after an hour of powering back on the trolling motor the thing will start.
What is my issue? (other than I should have put the money into more jeep parts as opposed to a water toay).
Stern drive oil is fine, engine oil is clean and full. Could it be heat? The take up looks clean etc.
2006 4.3 Mercruiser
Covert_Ops is offline   Reply With Quote
Old July 6th, 2008, 07:43 PM   #2
kickstand
circling the drain
kickstand's Avatar
vapor lock?
Is it Fuel Injected? If so get it on the computer and see whats going on.
Its just a 4.3 liter chevy car motor, trouble shoot it the same way.
Old July 6th, 2008, 07:45 PM   #3
Covert_Ops
not fuel injected. It is a carb. Which was just adjusted by the shop end of the year last year.....
What causes vapor lock?
Old July 6th, 2008, 07:52 PM   #4
Covert_Ops
Vapor lock... Could be, but the engine does not even crank over or anything.
Old July 6th, 2008, 07:55 PM   #5
kickstand
circling the drain
kickstand's Avatar
So you turn the key and get nothing out of the motor?
Sounds like your starter or solenoid could be getting some heat to them and screwing with something.....
Old July 6th, 2008, 08:05 PM   #6
Covert_Ops
just read a service memo on vapor locking... This is what I think I have.
I think if I idle a bit instead of shutting off I could fix my issue. It is probably due to heat. I have only owned outboards until this boat...
Any additional ways I can keep the heat down? I am thinking maybe adding another vent fan?
Old July 6th, 2008, 08:07 PM   #7
kickstand
circling the drain
kickstand's Avatar
with an IO it is not a bad idea to run the blower for a bit idle down and even for a couple minutes after you have shut down....they may help.
Old July 6th, 2008, 08:09 PM   #8
Bow_Extreme
Bow_Extreme's Avatar
I would also say ignition system. Starter/solenoid , battery, cables, wiring, etc. I would go thru the whole system and try to make it fail.
Bow_Extreme is offline   Reply With Quote
Old July 6th, 2008, 08:10 PM   #9
Covert_Ops
Yes.. nothing out of the motor when we turn the key.
I am with you.
Only I think it is vapor locking due to heat and then not restarting due to heat.
Runs about 160 while cruising. Then we cut it and it does not get to cool, it actually heats up a bit... Then we try and start and the heat sensors are not allowing the start.
It always starts after time which it is cooling i am sure.
Old July 6th, 2008, 08:11 PM   #10
Covert_Ops
When I get some time tomorrow I will let you know what i find on the ignition side of things.
Old July 6th, 2008, 08:11 PM   #11
Bow_Extreme
If you vapor lock, wouldn't the engine still turnover?
Old July 6th, 2008, 08:12 PM   #12
kickstand
circling the drain
kickstand's Avatar
It could be anything, I dont really know, but you just gotta start checking things otu and see what you find.
Old July 6th, 2008, 08:12 PM   #13
kickstand
circling the drain
kickstand's Avatar
I would think so yes.
Old July 6th, 2008, 08:13 PM   #14
Bow_Extreme
190 Degrees is normal operating temperature for most engines out there. I don't know that heat would be your main problem. Sounds like it's actually running a tad bit cool.
Old July 6th, 2008, 08:14 PM   #15
Bow_Extreme
Vapor lock usually causes intermittent running, runs and cuts out. I've done that to smaller 15 hp mercs before. It will always turn over.
Old July 6th, 2008, 08:17 PM   #16
bj house
bj house's Avatar
Ignition modules like to heat up fail then start working again after they have been off for a few.
Old July 6th, 2008, 08:27 PM   #17
Bow_Extreme
It sounds like a fairly simple solution considering the symptoms and it sounds like your probably a bit frustrated with it right now. Just think of it this way, I don't really know UPRocktoy but the problems with his boat motor probably takes the cake in comparison to your problem.
Old July 6th, 2008, 08:34 PM   #18
kickstand
circling the drain
kickstand's Avatar
Yeah, mine's self destructed at the moment, at least his just gets moody.
Old July 6th, 2008, 08:34 PM   #19
dreezy
Haggard Fab
dreezy's Avatar
With any boat I have every captained they have all been I/O's and I have always run the blower with the engine hatch open for a good couple minutes. Never had a problem with starting. I have however lunched a couple of lower units due to bad mehcanics.
Old July 7th, 2008, 06:36 AM   #20
dodger889
dodger889's Avatar
I would just replace the starter. Sounds like the brushes are getting bad and sticking. Does it even click like the solinoid is kicking in ??? If not then replace the solinoid.( shhh You can buy one at the auto part store will work for a boat just run the blower for about three minutes be for starting )
Page generated in 0.34831 seconds with 83 queries
