Lots of junk in carb - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 2nd, 2008, 09:21 PM   #1
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Default Lots of junk in carb
Well went to see what the deal was with the Jeep not running in prep for the parade.... Sorta wish i hadn't. Found that it was not getting any fuel other than that from the accel pump jets. When i took the primary fuel bowl off it was full of this kaki colored shit. Hard to explain but it was in small chunks, but was plyable. Not sure what it was, cleaned it all out, and it ran sweet....For 10 minutes.
Went to the gas station thinking maybe it was out of fuel (hard to trust the fuel gauge anymore), on the way i picked up an in line fuel filter to put just before the carb. When i tried to fire it up, same thing. I was so pissed i gave up on it for the day, but i'm thinking whatever it was has clogged it back up.
The jeep still has the factory pump and fuel filter (changed a few years back) Do you think that sitting for the past year has caused the stock filter to break up? It almost looked like hunks of it, but i can't be sure. Its big enough pieces to plug just about everything, including the primary jets.
My cell takes HORRIBLE pics, but maybe you can see something in there. You can see the chunks in the jet on the right, and some chunks in the bottom. I dont know what else it could be..?
Old July 2nd, 2008, 09:24 PM   #2
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
if the jeep sat for a long while with shitty gas it may be that or the filter pull it off and check it out.
Old July 2nd, 2008, 09:36 PM   #3
BigBlkYJ 355
U-Joints Fear Me
Basically it sat exactly one year. it still had 4th decorations from last year I always run premium or race gas since it pings on anything else. Would the gas solidify and make that gunk?
Old July 2nd, 2008, 09:44 PM   #4
unclebeaner
yes ive had it happen on my quads and my jeep more on quads for some reason with the racing gas it seems to happen
Old July 2nd, 2008, 10:05 PM   #5
BigBlkYJ 355
U-Joints Fear Me
hmm, well now i guess im kinda in a rock and a hard place. I'm gunna clean it out one more time tomorrow, but now that i have that fuel filter on there, hopefully it will catch any more shit that comes through. Ive got at least 5 gallons of new fuel in there, on top of who knows what.
Old July 2nd, 2008, 10:25 PM   #6
unclebeaner
i have that stuff in the 1 gal can that you soak the carb in it works great. you could pump the tank out and check it out.
Old July 4th, 2008, 10:03 AM   #7
jeepers48
jeepers48's Avatar
X2 drain the tank. Ive had the same thing happen. Condensation in the tank. During the "spring thaw" everything metal in my garage sweats and rusts. You can pick up some gas additive when you park the jeep for the winter months so that doesnt happen.
jeepers48 is offline   Reply With Quote
Old July 4th, 2008, 10:16 AM   #8
jeepnxj96
jeepnxj96's Avatar
either that or fill the tank completely full when you store it, less room for condensation, and your gas shouldn't go that rank for one year, even if it does you can still run on one tank of crap gas but be better off than having rust and whatever else from the water in the tank.
Old July 4th, 2008, 12:28 PM   #9
unclebeaner
personally if i know something is gonna be sitting i run minumum fuel in it and pinch off fuel line and run it out of fuel so the next year i can toss 5 gal in there and be ready to go.
Page generated in 0.27329 seconds with 51 queries
