WTF, plz help, mustang dying.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2008, 06:40 PM   #1
WEEEEEE
balls
WEEEEEE's Avatar
Send a message via AIM to WEEEEEE
Angry WTF, plz help, mustang dying....
http://www.youtube.com/watch?v=4aJs5IcrGos
its been doing this for a few months now after it sat all winter, your thoughts/opinions on the problem?
so far i have replaced the inline filter, new plugs, cap, rotor, plug wires, cleaned the IAC and MAF sensor, searched high and low for vacuum leaks found only one and plugged it good. next step is going to b investing in a fuel pressure gauge and obd1 scanner...
PS, plz dont get on me about the wheels...im quite aware of the amount of radiating from them. they came on the car and they arent my biggest concern at the moment....
WEEEEEE is offline   Reply With Quote
Old July 1st, 2008, 06:50 PM   #2
MISHOWJEEPER
NSFW
MISHOWJEEPER's Avatar
I know it's expensive, but put fuel in it! Seriously though, is that warmed up, or cold? it seems to be starving for fuel. check the pressure. you don't need a guage, just push the valve in on the fuel line and see if it shoots 10 feet or so.
MISHOWJEEPER is offline   Reply With Quote
Old July 1st, 2008, 07:25 PM   #3
CJalltheway
CJalltheway's Avatar
x2
Sounds like a fuel problem. Maybe the fuel pump.
CJalltheway is offline   Reply With Quote
Old July 1st, 2008, 07:43 PM   #4
prostock3
gimmie gimmie more
Send a message via AIM to prostock3
fuel pump
prostock3 is offline   Reply With Quote
Old July 1st, 2008, 07:51 PM   #5
WEEEEEE
balls
WEEEEEE's Avatar
it has fuel pressure out of the test valve, i was going to go fill up the gas cans and fill it up to c if it was somthing as dumb as that as soon as i can.
the pump sounds normal but i was kinda shying away from that b/c i dont wana do the work to change it if it isnt that.
annnd i drove it about 6 miles home no problem from the spot in the video (which was taken a month ago) i wiggled and hit everything i could and it ran fine so i hurried and drove it home but the next day when i went to go start it, same problem....
Old July 1st, 2008, 10:03 PM   #6
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
get a new one, you're facked.
check fuel pump, filter and lines for blockage
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old July 1st, 2008, 10:17 PM   #7
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
word
Old July 1st, 2008, 11:22 PM   #8
WEEEEEE
balls
WEEEEEE's Avatar
mk ty 4 info
i mean it starts fine and idles perfect 4 10 seconds then sputters and dies
BTW its not the non starting thing, that i was doing on purpose for no reason
its the sputtering and dying i am asking about if there was any confusion
Old July 2nd, 2008, 04:57 PM   #9
WEEEEEE
balls
WEEEEEE's Avatar
any more thoughts?
Old July 2nd, 2008, 08:23 PM   #10
sodapop
Support the Sport!
sodapop's Avatar
[lisp] Those rims are super sweet!! [/lisp]
Old July 2nd, 2008, 08:26 PM   #11
MotoX5874
unbound
MotoX5874's Avatar
the previous owner was certified badass (see wigger) and had like 400 lbs of stereo in the back as well so he could bump his rap yo
MotoX5874 is offline   Reply With Quote
Old July 2nd, 2008, 08:34 PM   #12
WEEEEEE
balls
WEEEEEE's Avatar
"PS, plz dont get on me about the wheels...im quite aware of the amount of awesomenessyodawg radiating from them. they came on the car and they arent my biggest concern at the moment...."
thank you im very aware......if i had the $$$ for new ones, the old ones would burning right now.....
Old July 3rd, 2008, 12:14 AM   #13
sodapop
Support the Sport!
sodapop's Avatar
sorry couldn't help myself.... it was a moment of weakness.
Old July 3rd, 2008, 12:36 AM   #14
WEEEEEE
balls
WEEEEEE's Avatar
lol its ok, i get it on a regular basis
Old July 3rd, 2008, 07:15 AM   #15
dodger889
dodger889's Avatar
Well you video did very little to hear the problem if you are having engine problems it would have been nice to be able to see the motor while you where doing what you where doing. All I could hear was the wind hitting the mic and the starter kicking iin.
Here is something I would like to know it ran before you put it away??
How many miles on this engine ??
Did you fog the engine before you set it for the winter??
Did you put gas stabilze in it before you stored it with a full tank of gas??
And last but not least how well did it crank the frist time you tried to start it this year cranked easy, sorta hard, real hard like something was stuck, or you don't know???
If by chance it didn't have alot of gas in it then your problem could be just a cloged fuel sock in the tank or water .
This is just a few thoughts for in general for any car.
The other thing to try is disconect the battery leave it off over night reconect and start it.This could clear up the computer.
Old July 3rd, 2008, 05:05 PM   #16
WEEEEEE
balls
WEEEEEE's Avatar
120,xxx on the engine
and it was moved about 6 miles from my grandparents garage back to my house and back there again about 4 times, it just needed a jump, no i didnt "fog" it or put stabilizer in the gas. it started doing last fall right b4 1 put it away now that i think of it, every so often it would run perfect, so i took adavantage of it and moved it while i could, then next start up. dies
Page generated in 0.33810 seconds with 71 queries
