1987 Kawasaki KLR 650 Electrical problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 1st, 2008, 11:43 AM   #1
mikeswmikesweat73
Crazy
mikeswmikesweat73's Avatar
Default 1987 Kawasaki KLR 650 Electrical problem
So I am driving to work yesterday and lose all power at about 55mph. No power at all for about 5 minutes. Then it miraculously starts back up and I am on my merry way. Get on the Eway does it again. wait about 10 minutes starts back up with a lot of cranking. Turn around get off the Eway stops for good this time no power even after I got out of work. Go out this morning undo the battery hook it back up. Starts ok, ride it for about 10 hard minutes. Does the same thing twice. I am thinking it's the voltage regulator, but I am no mechanic. PLEASE HELP. can I test the voltage regulator? could it be the ignition switch? what else might be overheating? Any help would be greatly appreciated.
Thanks,
Mike
mikeswmikesweat73 is offline   Reply With Quote
Old July 1st, 2008, 11:51 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
my shot in the dark would be a piece of dirt in the carb
Old July 1st, 2008, 02:37 PM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
no engine power or no electrical power? I also have a klr650
Old July 1st, 2008, 10:34 PM   #4
mikeswmikesweat73
Crazy
Yeah no engine or electrical power should have clarified that, sorry.
Old July 1st, 2008, 11:06 PM   #5
booblinker
Sore and Tired 24/7
booblinker's Avatar
Coil, Or bad ground.
Old July 2nd, 2008, 05:48 PM   #6
Christmas Cookie
x2...at least its a place to start
Old July 2nd, 2008, 06:58 PM   #7
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
x3
coil or bad connection
Old July 3rd, 2008, 03:20 AM   #8
mikeswmikesweat73
Crazy
Thanks, I've been checking the grounds. I am taking it in in the morning to have the coil, cdi, stator, voltage regulator checked I appreciate the input and I'll let you know the outcome
Old July 5th, 2008, 03:05 AM   #9
mikeswmikesweat73
Crazy
Turns out it was a god damn corroded fuse box. I've got it running like a champ now, thanks,
Mike
Old July 5th, 2008, 07:53 AM   #10
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
good to see your up and running again. just an FYI for you. Kaws are notorious for not using weather proof connections. I would suggest to you to use dielectric grease in all the connections where any water can reach them. it will help in the long run to stave off corrosion.
Yetti
Old July 5th, 2008, 08:42 AM   #11
Nuggets
I fix stuff!
Nuggets's Avatar
I was gonna guess bad ignition module but you beat me to the fix. Glad you got it.
Page generated in 0.26473 seconds with 56 queries
