brake work - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2008, 07:38 PM   #1
t buff
t buff's Avatar
Default brake work
I got a yj with 4 wheel disc i am getting no pressure pedal goes to the floor. I have a corvette master. what i am wondering is on a corvette master is it the same as a disc drum master , does the front work the back and back work the front? i need help on this one
t buff is offline   Reply With Quote
Old June 29th, 2008, 08:07 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
master cylinders are all the same the booster side is rear and the fronts are at the other end. if its a no pressure issue I would see if you have a blown flex hose. I have seen them blow up like ballons on rear disc conversions.
Yetti
Old June 30th, 2008, 10:57 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Which Corvette master (what piston size?).
Did you bleed the master?
Did you bleed the brakes?
Old June 30th, 2008, 06:29 PM   #4
2kids=nojeepmoney
unless i misread this, i don't think all m/c are the same like you stated. CJ m/c vs. YJ m/s are reversed front/rear in comparison to each other
2kids=nojeepmoney is offline   Reply With Quote
Old June 30th, 2008, 06:34 PM   #5
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
did you try gravity bleeding it first? maybe air in master
Old June 30th, 2008, 09:03 PM   #6
dodgeboy
redneck truck club
dodgeboy's Avatar
did you check the push rod and make sure its right??? might be to short or to long. if its to long you could of rolled the cups in the master. im sure you looked for leaks before asking for help. so i would say if you blead it and still having a problem you might of rolled the cups!
dodgeboy is offline   Reply With Quote
Old June 30th, 2008, 09:19 PM   #7
t buff
t buff's Avatar
The master is from a 69 vette- i bench bled it gravity bled it bled from the calipers to the master nothing works- i pinched off the rear brake hoses and tried that - nothing the push rod is the stock yj one i tried to adjust that when i make it shorter the pedal comes up but the calipers dont pinch the rotors hard enough to stop
Old July 1st, 2008, 09:17 AM   #8
dana202
I don't know to much about a Jeep,but heres some info http://auto.howstuffworks.com/master-brake2.htm . I do know if you have 4 wheel disk brakes you need a 4 wheel disk brake master cylinder. I used one out of a 2001 chevy truck with 4 wheel disk brakes. I took a screw driver and pushed in the piston on my old master and took a measurement and then I measured the new one and they were the same. My brakes were soft and would push to the floor after I put on rear disk brakes,now there rock hard. hope this helps.
dana202 is offline   Reply With Quote
Page generated in 0.26161 seconds with 47 queries
