XJ drums won't work - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2008, 10:01 AM   #1
clint357
Web Wheeler Extraordinair
clint357's Avatar
Default XJ drums won't work
OK I've never done drums before, but mine were totally shot. With my rear wheels off the ground, they would just free-spin while in gear and would not stop with the brakes. I just put new shoes on, and still the same story. The "BRAKE" light is also on all the time. What do I need to do?
clint357 is offline   Reply With Quote
Old June 29th, 2008, 11:49 AM   #2
jbsjunk
Little Member
jbsjunk's Avatar
Sounds like the wheel cyls are frozen. As for the light, odds are the fluid is low, or the e-brake is on a click or two.
Old June 29th, 2008, 11:53 AM   #3
clint357
clint357's Avatar
Thumbs down
Front brakes work fine, so I don't think the fluid is low. E-brake is off, and the cyls can be compressed by hand.
Old June 29th, 2008, 11:55 AM   #4
clint357
clint357's Avatar
I do have a non-abs axle on one side though. Could the ABS be not allowing the brakes to function?
Old June 29th, 2008, 12:07 PM   #5
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
try bleeding the brakes, once you do that adjust the drums so that there is slight drag on them. make sure it's even side to side.
Old June 29th, 2008, 12:29 PM   #6
junk90xj
ALLPRO AUTO
junk90xj's Avatar
make sure the prop valve isnt stuck too.
http://www.apalansing.com/
Old June 29th, 2008, 01:14 PM   #7
clint357
clint357's Avatar
WAT?
Old June 29th, 2008, 06:26 PM   #8
clint357
clint357's Avatar
So how do I go about fixing this problem? Should I bleed the brakes and see if that works, or is there a way to check the prop valve?
Old June 29th, 2008, 07:11 PM   #9
PavementPounder
PavementPounder's Avatar
Open the rear bleeders, step on the pedal, and see of fluid is pushed out. If nothing is moving, then the master isn't pumping or the prop valve is not open.
Page generated in 0.56947 seconds with 50 queries
