Brake Question, Piston split in half - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2008, 08:16 PM   #1
Chiefwoohaw
Pokerob is my B*tch!
Chiefwoohaw's Avatar
Default Brake Question, Piston split in half
What would cause a piston to split in half?
About a week ago I felt my rear brake dragging on the F350. I thought it was the parking brake and played with it a while and all seemed good.
Going to work yesterday I loose all pedal and try not to kill anyone with my run away truck.
I get out of the truck and the rear passanger side is covered in brake fluid.
I pull the wheel and take off the caliper and one of the dual pistons is cracked in half and looked pretty awesome.
Swaped calipers and pads and all was good.
So . . . . what causes something like that to happen? Heat over a long time?
Old June 29th, 2008, 09:21 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
were they plastic or metal piston's? I have seen them broke on reman'd just from them putting them together. Who knows why they broke in your case. Are they original or reman'd calipers to start with?
I don't understand why you lost all your brakes... It should have been a low pedal but still have front brakes.
Old June 30th, 2008, 08:13 AM   #3
Chiefwoohaw
They were Metal.
The peddle was low to let me slow down and then nothing. . . . resivor was drained and had to plead all 4 calipers. The MC is holding up though, I thought that they went bad, slealed up, woldn't work again when they were emptied. Guess I was wrong on that one.
Old June 30th, 2008, 08:18 AM   #4
deuce228
Redneck Poser
deuce228's Avatar
Originally Posted by InBBA View Post
They were Metal.
The pedal was ?low to let me slow? down and then nothing. . . . reservoir was drained and had to bleed all 4 calipers. The MC is holding up though, I thought that they went bad, sealed up, woldn't work again when they were emptied. Guess I was wrong on that one.
Drinking this morning Drew?
Old June 30th, 2008, 09:51 AM   #5
FlatFender
Tap Tap Splat
FlatFender's Avatar
They were Metal.
x2
wtf dude?
Old June 30th, 2008, 10:44 AM   #6
Chiefwoohaw
The pedal went to the flow and lost pressure at first when the fronts were operating but then nothing, not fluid and no brakes.
Yup, bad typer when multi-tasking.
but I could use a drink that is for sure!!
Page generated in 0.35615 seconds with 41 queries
