How much is to much truck? - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2008, 06:53 AM   #41
IFS SUCKS
I like trees
IFS SUCKS's Avatar
I would never own a 6.5 diesel worthless piece of shit!
IFS SUCKS is offline   Reply With Quote
Old July 9th, 2008, 09:08 AM   #42
cronus
cronus's Avatar
Originally Posted by XXXJ View Post
There is not a lot of magic going on. Disc brakes are what they are, (except anti-lock), and size matters. They only feel better because they are new.
You're right size does matter, the brakes on the 1/2 ton are bigger that's why they stop better. The rear disc brakes also make a big difference.
cronus is offline   Reply With Quote
Old July 9th, 2008, 09:18 AM   #43
XXXJ
Desert Rat
XXXJ's Avatar
Rear discs are an unbelievable improvement, can be the difference between stop and not.
The rest is a roll of the dice, I'm just saying use the proper tool for the job.
On the other hand, thats why we carry insurance.
Old July 9th, 2008, 09:53 AM   #44
I can't compare or discuss a deisel because I have no experience with one. I can just say that for the amount I tow I couldn't justify the difference in cost.
However, I can discuss 1/2 ton to 3/4 ton. I've had and towed with both. I had a 2000 1/2 ton with a 5.3 w/3.73 gears. It had a hard time staying in overdrive and seemed very under powered towing my jeep on a flat bed. I had a 2004 2500HD crew cab with a 6.0 & 4.10 gears. Towed great. Rode like shit and the daily around town mileage dropped from 16-17 to 12-13. At the same time I moved to an enclosed trailer for the jeep. Still towed good. But, since I only tow once in a while as compared to driving it every day and alot of out of town business trips, I thought it was not practical.
I went to a 2007 1/2 ton with the Chevy Vortec Max 6.0 & 4.10 gears. Now I have what I consider a perfect tow rig. It still has the power that the HD had but the ride like a 1/2 ton should. It still has a great ride, a 10,000 towing capacity and FAR BETTER BRAKES than the earlier 1/2 ton has. Note, I never am putting any payload in it so I don't need the stiffer springs. The brakes will stop my 20ft enclosed trailer with the jeep in it exceedingly well, even with the trailer brakes turned off. I had an instance while going to the mounds a couple weeks ago where a guy suddenly decided to turn left in front of me. I slammed on the brakes and the antilocks did their job allowing me to swerve around him totally under control. I am a firm believer in equalizer hitches and will always use one. If you've never tried one, you should. It's worth the money.
RE the pic above showing a flipped trailer. Who says it has anything to do with it being a half ton? Was the trailer balanced properly? Equalizer hitch? Electric brake failure? There are a dozen reasons why it may have flipped & none of them have anything to do with the rating of the truck.
Here's a pic of my 2500HD off the road with my trailer. Shit..... maybe it would have saved me if I had a 1 ton dually with a diesel.
Old July 9th, 2008, 10:46 AM   #45
XXXJ
Desert Rat
XXXJ's Avatar
That sux.
Sometimes you do everything right and "bad" just happens.
Other times you do everthing wrong and it works like it shouldn't.
Rolling the dice.
The only thing I've seen work 100/100 on ice is studs or chains.
But this has gone way off topic....
Old July 9th, 2008, 11:06 AM   #46
steveo
In the band!
Thats okay stevie, you don't have to cry.
When you grow up, and get a real job you can get a big truck like daddy.
why is it the guys with little dicks are the ones that say penis size doesn't matter!!
I was Crying on behalf of your parents, must have been hard for them to raise a retard. I graduate in 5 months, I bet i make more my first year out than you made this year. heres a pic of my grad present.
Old July 9th, 2008, 11:07 AM   #47
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
I'm just fuckin around. That was a steep pass and my guess is he was going way faster than he should have been (traffic was flowing at 80) and had to do some sort of maneuver which resulted in an over correction. I just like to give the half ton guys shit to boost my own tattered ego
Yes it would have. Mine has never sent me off the road...
Nuzzy is offline   Reply With Quote
Old July 9th, 2008, 11:10 AM   #48
steveo
In the band!
the trucks the 6.5 came in were great trucks. the best thing to do with a 6.5 is to replace it with a cummins.
Old July 9th, 2008, 11:19 AM   #49
Nuzzy
Nuzzy's Avatar
The best thing to do with any motor that doesn't say Cummins is to replace it with a Cummins...
<-------- Really isn't a brand whore.
Old July 9th, 2008, 11:37 AM   #50
XXXJ
Desert Rat
XXXJ's Avatar
Grad present?
Please stop, that's funny.
Old July 9th, 2008, 02:25 PM   #51
KartRacer
Blowd up
KartRacer's Avatar
When are the new industry standard tow ratings going to go into use?
Old July 9th, 2008, 05:29 PM   #52
kickstand
circling the drain
kickstand's Avatar
No shit dummy, newer half tons have better brakes then older half tons. They also have better suspensions, as much or more power, and ride better....do you get it yet?
Yes a same year 3/4 ton will out tow a same year half ton every day....
Old July 9th, 2008, 05:44 PM   #53
XXXJ
Desert Rat
XXXJ's Avatar
Originally Posted by UP_ROKTOY View Post
Yes a 3/4 ton will out tow a half ton every day....
There, I fixed it for you.
It's about GCWR.
Old July 9th, 2008, 05:58 PM   #54
chevotass
chevotass's Avatar
215,000 miles and my 6.5 is still running great. its quiet and rides great. dont hate the playa. hate the game.
Old July 9th, 2008, 07:34 PM   #55
kickstand
circling the drain
kickstand's Avatar
It's about GCWR.
your a retard
Old July 9th, 2008, 07:48 PM   #56
XXXJ
Desert Rat
XXXJ's Avatar
your a retard
Just because you ignore facts, they do not cease to exist.
Name calling is the last desperate act in an argument lost.
Old July 9th, 2008, 07:49 PM   #57
It's about GCWR.
Based upon what? Towing a jeep on a trailer or towing a 42ft gooseneck? His original question states that he will only tow 10% of the time. He has not said what he plans to tow but I think most everyone is assuming something like a jeep on a trailer. If the package fits within the GCWR, spending extra money just to say he has a 3/4 ton is a waste of money.
Old July 9th, 2008, 09:31 PM   #58
kickstand
circling the drain
kickstand's Avatar
Yes, your right, you win. Your 1990 3/4 will out tow a brand new half ton any day, and ride better, and has a stronger frame, and better motor, and will get better mileage doing it. I am sorry
Old July 9th, 2008, 09:37 PM   #59
Mclovin
"The Situation"
Mclovin's Avatar
my 03 1500 Ram with the 5.7 tows PERFECT.. so far biggest load.. s10 3 quads and 5 people.. didnt break a sweat felt perfect at 75 and brakes were up to par !
Old July 9th, 2008, 09:51 PM   #60
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I answered my own question, I got the truck of my dreams, i love the 7.3 Diesel:) 100&#37; stock now, wont be at the end of the month
I'm the man in White.
Page generated in 0.45801 seconds with 84 queries
