Tire question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2008, 09:04 AM   #1
joppermann
joppermann's Avatar
Default Tire question
What does the middle number mean in the following?
32X11.5X15 I know what 32 and 15 stand for, but the 11.5 has me confused. Does that mean I'd need new rims if I'm running 31X10.5X15's?
Thanks...
joppermann is offline   Reply With Quote
Old June 28th, 2008, 09:21 AM   #2
Guitardrumr
Guitardrumr's Avatar
Send a message via AIM to Guitardrumr
That middle number is the width. Depending on the width of your wheels, you may need new ones if you're set on running that size. Some of the other guys on here should be able to tell you what width tire will fit on what width wheel.
Guitardrumr is offline   Reply With Quote
Old June 28th, 2008, 10:25 AM   #3
joppermann
joppermann's Avatar
I plan on using my stock rims, in my avatar...I cannot find 32X10.5X15's in any of the catalogs...
Old June 28th, 2008, 10:42 AM   #4
jpr Jeremy
LS Powered
jpr Jeremy's Avatar
you'll be fine w/ stock wheels, thats what I run right now, the 32x11.5's might rub the bottom corner of your flairs if you aren't running any lift.
jpr Jeremy is offline   Reply With Quote
Old June 28th, 2008, 11:18 AM   #5
joppermann
joppermann's Avatar
I have a 2 inch lift which is why I want to go from 31's to 32's when its tire changing time...
Page generated in 0.23817 seconds with 38 queries
