brake help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2008, 01:24 AM   #1
OldManGrand
Default brake help
does anyone have a diagram or picture, or even a 67-70 ford with factory disc brakes i could look at, i replaced all of the brake lines on a 68 galaxie but dont remeber where they go, there is a distribution block, and then a hold off valve. i would love to have the car on the road for the fourth
OldManGrand is offline   Reply With Quote
Old June 28th, 2008, 03:14 AM   #2
bigcountrysg
Countryboy
bigcountrysg's Avatar
Is it the same for all fords for those years. I have a buddy who has quite a few falcons. I can get over there tomorrow and take a picture and post it up for you if it would help.
bigcountrysg is offline   Reply With Quote
Old June 28th, 2008, 03:25 AM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
from what fred told me, there were two different types of setups.... i think 5 and 8 block ports??
Old June 28th, 2008, 08:13 AM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
those are real simple systems. the side of the master cylinder closest to the booster is for the rear brakes and feed the back of the proportioning valve, then one line out to the rear axle.
the front brakes are fed by the front half of the master and then into the proportioning valve. some valves have one line in and one out to a splitter. other ones have 2 lines out, one to each wheel in front.
Yetti
Old June 28th, 2008, 11:12 AM   #5
OldManGrand
its simple until you get up front...lol the 2 different blocks throw me off because you have lines that come from the master cylinder to the distribution block then on the 67-70disc setups, from the distibution block to a hold off valve, pics would help put alot, or if he is close to livonia and wouldn't mind me taking a look at one that would be a great help
Page generated in 0.17570 seconds with 38 queries
