Vinyl Decall Removal - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2008, 12:33 AM   #1
bigcountrysg
Countryboy
bigcountrysg's Avatar
Default Vinyl Decall Removal
I know I can use a heat gun heat it up and remove it like that. But what about the 3m removing disc that you can get. Does it hurt the paint of the vehicle.
I have a vinyl decal on my truck I am wanting a change in look. So I am deciding to remove it, then wash and buff the truck. I know I may have a shadow from the decal.
bigcountrysg is offline   Reply With Quote
Old June 28th, 2008, 02:30 AM   #2
Rockstar
sɐƃǝʌ sɐן
Rockstar's Avatar
Rockstar is offline   Reply With Quote
Old June 28th, 2008, 02:32 AM   #3
bigcountrysg
Countryboy
I was wondering if anyone has used it before. What was the results how did they like it. Or should I just do it the old fashion way with a heat gun and peel it all off.
Old June 28th, 2008, 03:29 AM   #4
mojo
Wha Happen???
mojo's Avatar
Send a message via MSN to mojo Send a message via Yahoo to mojo
goo gone
mojo is offline   Reply With Quote
Old June 28th, 2008, 04:57 AM   #5
Bishop
Bishop's Avatar
i have used them. they work good, dont do a thing to the paint as long as there isnt any dirt on the surface. and as long as you dont over do it cuz you can burn the paint if you use too much presure in one spot too long.
Old June 28th, 2008, 09:26 AM   #6
ppkaprince98
Size Matters (.)(.)
ppkaprince98's Avatar
Originally Posted by mojo View Post
goo gone
x2.......Goo Gone, once you peel off the decal to remove all the sticky shit left over!!!!!!!!!
Old June 28th, 2008, 04:57 PM   #7
mojo
Wha Happen???
mojo's Avatar
Used to use it at CEC let it soak on the decal and it will start penetrating the glue around the edges m,akes it easier to peel off, then keep soaking the glue.
Page generated in 0.15327 seconds with 44 queries
