winch no spool in - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 27th, 2008, 07:43 AM   #1
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
Default winch no spool in
my friend has a tabor 9000 and the winch will spool out perfectly fine but not back in. if he switchs the neg and pos on battery it will come back in. he has replaced all the solinoids but still no worky.. any ideas on what it would be?
nate4d is offline   Reply With Quote
Old June 27th, 2008, 07:47 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
?bad remote?
Old June 27th, 2008, 07:52 AM   #3
bigjay
The Man Myth And Legend
bigjay's Avatar
Location: i can piss on the allegan and barry county line at the same time.. ...
its junk...ill give 50 bucks or it..
bigjay is offline   Reply With Quote
Old June 27th, 2008, 08:33 AM   #4
nate4d
Gnarley Davidson
nate4d's Avatar
thats dumb, please shut up
Old June 27th, 2008, 08:53 AM   #5
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
He switched the leads going to the battery? That just uses the same circuit that was working for out work for in, not show the issue.
I haven't pulled apart anything but my Warn, but it's all gonna be similar.
If he wants to swap something, swap the motor fields. On my warn they were marked F1 and F2 and A. F1 and F2 are the ones you want to swap. Besides when rewiring, don't mess with the battery, leave it like you normally have it seutp.
If by switching the fields the winch spools in and not out, then I would change the solenoid. If still only spools out then the motor is kaput. When my motor died, it died in both directions, so I'd guess it's just a solenoid.
Old June 27th, 2008, 09:06 AM   #6
fsumotorhead
N8KVB
I would still suspect the remote rocker switch or the power in wiring in the remote lead, try to jumper the pins with the battery connected as normal and try to spool it in
Old June 27th, 2008, 12:22 PM   #7
nate4d
Gnarley Davidson
nate4d's Avatar
he is gonna check with someone elses remote tonight .
Page generated in 0.16613 seconds with 44 queries
