i need help or a carb nevermind fired today. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2008, 08:54 PM   #1
hman1991
hman1991's Avatar
Send a message via AIM to hman1991
Default i need help or a carb nevermind fired today.
ok well its been like a year and i am frustrated. i put a 1.6 in my sammy with efi and got the harness striped down and in and no spark. you can hear relays and stuff kick on and turn over but no spark. well i cannot figure out the problem. it was a 94 tracker with 3 speed auto that the harness and ecu came out of. i do not know what to do id like to make her run. so i guess if i cannot get it id like to get a carb intake and stock carb and try my luck with that again. unless there is someone out there local that can help.
hman1991 is offline   Reply With Quote
Old June 29th, 2008, 11:24 AM   #2
more4x4
Audi Tech/4x shop coowner
more4x4's Avatar
check your ignition coil, to see if you are getting voltage at it when the ignition is cranking. if you are getting voltage at the coil but none out of the secondary side of the coil then you need a coil.
more4x4 is offline   Reply With Quote
Old July 1st, 2008, 08:14 PM   #3
jimmyroyse
webwheeler
jimmyroyse's Avatar
fyi..
auto's and 5 speeds have different computers.
jimmyroyse is offline   Reply With Quote
Old July 5th, 2008, 09:12 AM   #4
hman1991
hman1991's Avatar
well i think i have tracked down my problem. i pulled the harness and cleaned it up. found 2 wires that i was grounding that should have been a switched 12v source. i am also gonna try to pick up a 5 speed ecm for it. well i am keeping my fingers crossed.
Old July 5th, 2008, 09:23 PM   #5
hman1991
hman1991's Avatar
well a guy on the zuki boards helped me. so put harness in and got it to fire. hook up the tank and see how she runs now.
Old July 7th, 2008, 06:34 AM   #6
jimmyroyse
webwheeler
jimmyroyse's Avatar
any updates?
i've been away from the computer for a week.
Page generated in 0.24944 seconds with 41 queries
