reverse shackle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2008, 05:22 PM   #1
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
Default reverse shackle?
good bad or ugly on a cj? discuss
Old June 25th, 2008, 05:33 PM   #2
rentalrider
rentalrider's Avatar
I love mine ('86 CJ7) but not sure if it's worth all the extra $. Had po not installed, I pro'ly wouldn't have either. But like I said, it works well in my rig.
Old June 25th, 2008, 05:45 PM   #3
unclebeaner
already on rig but debating whether or not to remove it
Old June 25th, 2008, 06:12 PM   #4
I personally don't like them. But if you have a habit of bashing your shackles/hangers into rocks, you won't bend your springs like you will with forward shackles.
Old June 25th, 2008, 06:15 PM   #5
unclebeaner
it will be used for trailriding,sand, and some rocks every now and again. i dont think it would be a good idea to jump it like general lee with this set up
Old June 25th, 2008, 06:16 PM   #6
Renegade II
Coil springs are for pens
Renegade II's Avatar
I'm about to put it on the 8 project, already have it on a 5 & 8. Easy/cheap to make your own if you plan it out. Works well.
Old June 25th, 2008, 06:36 PM   #7
2kids=nojeepmoney
shackle reversals don't work well with stock (flat) springs - such as worn-out CJ springs or stock YJ springs.
if you've got lift springs they work well. but if you have really stiff springs or tightened the crap out of the bolts, its not going to help much.
2kids=nojeepmoney is offline   Reply With Quote
Old June 25th, 2008, 06:47 PM   #8
unclebeaner
im unsure hwat im gonna run spring wise but it will be SOA
Old June 25th, 2008, 11:36 PM   #9
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
Had shackle reverse and took it off. Much better characteristics and control with shackles forward for my situation. CJ, low arch springs, SOA.
The need for long slip DS is annoying and they have some weird tendencies when trying to climb steep shit.
Nuzzy is offline   Reply With Quote
Old June 25th, 2008, 11:50 PM   #10
unclebeaner
such as?
Old June 26th, 2008, 12:16 AM   #11
Nuzzy
Nuzzy's Avatar
Originally Posted by unclebeaner View Post
such as?
Climbing and cresting rocks, my front would try to walk away from the rig. Dropping in to obstacles, I'd get the same thing. I've seen more than a few long slip drive shafts still pulled apart at the worst possible times. Was also "S"ing fronts more under torque since the axle could pull the spring forward more easily.
Old June 26th, 2008, 12:32 AM   #12
unclebeaner
thats the reason i was un-sure i may take it off
Old June 26th, 2008, 08:46 AM   #13
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
But you will anyway....
Old June 26th, 2008, 02:18 PM   #14
unclebeaner
i know
Page generated in 0.30485 seconds with 65 queries
