Roll over engines ok? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2008, 05:19 PM   #1
medicbear
Ax me bout ebonics!
medicbear's Avatar
Default Roll over engines ok?
Lookin at a Jasper Remanufactured engine that was in a roll over in an XJ anything i should be aware of when dealing with rolled engines?
medicbear is offline   Reply With Quote
Old June 25th, 2008, 05:22 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
i'd pull the oil pan and bearing caps to see if it was run upside down. the pickup sucks from the bottom of the pan. no oil there equals starved engine.
Old June 25th, 2008, 05:24 PM   #3
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
if it quit when it flipped you should be in the clear.
Old June 25th, 2008, 05:25 PM   #4
Shotgun
I only wheel with boats.
Shotgun's Avatar
just what he said, I had a friend of mine change the 3.8 out in his GTP with a engine from the bone yard with 36k on it, little did the yard disclose until he changed it and top swapped the block and it knocked in the first 3 miles did he know. they failed to disclose and since he top swapped it they would not take it back. He was out 2+ grand
Old June 25th, 2008, 05:28 PM   #5
Renegade II
Coil springs are for pens
Renegade II's Avatar
I wouldn't buy anything for more than core value if I couldn't hear it run and check the oil pressure.
Old June 25th, 2008, 05:34 PM   #6
medicbear
Ax me bout ebonics!
medicbear's Avatar
he wants 600 for it...
Old June 25th, 2008, 05:38 PM   #7
dodger889
dodger889's Avatar
How many miles on it..Roll over can be bad new on motors. and very few I have seen have shut off right away. I think I would want to see how bad of a roll over it was personly.
Old June 25th, 2008, 05:40 PM   #8
Freak
Wheelin the HD
Freak's Avatar
I rolled mine and its fine, but then as soon as it rolled I turned it off too...
Old June 25th, 2008, 05:47 PM   #9
medicbear
Ax me bout ebonics!
medicbear's Avatar
he said it ran fine afterwards and nothing wrong with it... i just mailed him to ask how long it ran while it was on its side or upside down.... he said its only got 45k on it since he bought it
Old June 25th, 2008, 05:56 PM   #10
medicbear
Ax me bout ebonics!
medicbear's Avatar
he said maybe 2 seconds and then he shut it off he said it ran fine afterwards... so it basically comes down to that or a salvage yard engine for 425 that has 123k on it they said they ran test and checked the compression and it was fine...
Old June 25th, 2008, 05:59 PM   #11
unclebeaner
if its hooked to the trans and you unsure you can take a oil pressure gauge over there and roll the motor over with some cables and a battery. then you can do you compresion tests so on an so forth
Old June 25th, 2008, 06:02 PM   #12
medicbear
Ax me bout ebonics!
medicbear's Avatar
yea unfortunately thats beyond me lol
Old June 25th, 2008, 06:05 PM   #13
dumperdave
dumperdave's Avatar
I bought a 4.0 for a cherokee that was rolled and I had no trouble with it. Try to talk him down a little!
dumperdave is offline   Reply With Quote
Old June 25th, 2008, 06:10 PM   #14
Yep, as noted, its a crapshoot. If it was sitting there upside down for 90 seconds running without oil, that'd be pretty bad.
There are some engines that will actually hydrolock on their own oil in a roll (roll a toyota 3.0 on its passenger door, for example).
I'd definately pull the plugs to look for oil in the chambers.
Old June 25th, 2008, 06:28 PM   #15
medicbear
Ax me bout ebonics!
medicbear's Avatar
well all i got is he rolled it maybe ran for 2 seconds... says it ran fine afterwards... 45k on it..its all the way down in romulous...
or the 123k salvage engine that is pretty local for 425...
Old June 25th, 2008, 06:29 PM   #16
unclebeaner
were in romulus
Old June 25th, 2008, 06:47 PM   #17
medicbear
Ax me bout ebonics!
medicbear's Avatar
were in romulus
if u dont mind checkin out the engine for me.... its at k & s customs llc i guess at least thats where the email originated... all i know is shortly after its in ill be takeing a LONG drive to TX
Old June 25th, 2008, 06:56 PM   #18
beejers
always building
beejers's Avatar
sent PM. buddy has a few motors.
beejers is offline   Reply With Quote
Old June 26th, 2008, 04:35 PM   #19
medicbear
Ax me bout ebonics!
medicbear's Avatar
ok well blew out the lower end of the engine today so its down to the jasper for 650 shipped he said he killed within 2 seconds of the roll over and said it ran great after... with no warranty or the salvage for 425 with 123k and a 30 day warranty they said they run tested fine before pullin it....
Page generated in 0.30014 seconds with 80 queries
