What trans is this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2008, 04:22 PM   #1
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Default What trans is this?
It's in a 79 Chevy P-30 Step Van with a Cummins 3.9L 4BT. I think it's a 47rh. I really could not get a good shot of the cover with it's finned and the front part of the case only has a tiny little cover to get at the converter bolts.
Old June 25th, 2008, 05:43 PM   #2
medicbear
Ax me bout ebonics!
medicbear's Avatar
this help? http://www.overlanddiesel.com/71/243...ession*id*val* surprised how hard it was to find info about this thing on the net
medicbear is offline   Reply With Quote
Old June 25th, 2008, 06:45 PM   #3
PavementPounder
PavementPounder's Avatar
Lolz @ Rocky.
Old June 25th, 2008, 07:17 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Funny but that would not be the stock trans then as they only came with; t19 (ford pattern), sm465, th400
Old June 26th, 2008, 01:47 PM   #5
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Yeah but some also had a ford tranny in them to. All depends on the adapter plate on the back half of the engine.
Old June 26th, 2008, 02:29 PM   #6
Tom
Because racecar
Tom's Avatar
If it is a 47rh someone put it in there, can you take the dog house off and take a pick from there and/or take a pick of the pan?
Old June 29th, 2008, 04:52 PM   #7
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Top half looks exactly like this one.
Mine
I thought a th400 had a huge opening in the bottom of the bell housing. Not an almost enclosed bottom with a small access cover to the t.c. bolts. Th475?
I'll have to wait till I pull it to get a pan shoot since it's only 18" or so off the ground.
Old June 29th, 2008, 05:55 PM   #8
Mine
Isn't a TH475 just a TH400 with straight cut gears? So the case woudl be the same, I'd assume...
Old June 29th, 2008, 06:25 PM   #9
Rocky
AAA GOLD ROCKS!!!!!
Rocky's Avatar
Not sure but the more I read it an odd ball case (cut out at the top vs the standard th400 point and a cast al inspection cover and pan.)
Page generated in 0.30574 seconds with 51 queries
