Subwoofer Box - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 25th, 2008, 12:20 AM   #1
ddeadserious
ddeadserious's Avatar
Default Subwoofer Box
I'm getting a subwoofer for my XJ, just a single 8" sub to add a little bass(it's only 900 watt's max, that only a little, right?).
My Jeep is lacking floors, and although I'm working on fixing them, it'll be a while, and aside from that, my door and window seals suck.
So I'm planning on my "system" to see moisture. The amp will probably get mounted to the back of the back seat, so it should stay high and dry. The sub box will be secured to the floor in one way or another, and will surely see some water. The subwoofer is a kicker, and is marine-ready, so I'm not concerned about it getting wet.
I'm concerned about the enclosure..
I've heard MDF isn't too fond of water and moisture. What if I were to herculine it to seal it off, would wetness still have ill effects on it?
I don't have the skills to do fiberglass, so that's out, besides, it uses MDF for a frame most of the time, right?
Isn't plywood a bad choice due to the fact that could vibrate apart or something? Why not use plywood? How well does plywood deal with moisture?
Plexiglass sub boxes are so gay, not to mention they sound like kaka, don't even suggest it.
Suggestions, advice, ideas?
thanks in advance.
ddeadserious is offline   Reply With Quote
Old June 25th, 2008, 12:28 AM   #2
muddin_wolverine
muddin_wolverine's Avatar
i fiberglassed my box, it works great, started with mdf then wraped it in fiberglass. lol and subs make an interesting sound when pushing water instead of air, mine has been completely submersed a few times haha. i also did the inside. the herculiner should work but i wouldnt consider it permenant
muddin_wolverine is offline   Reply With Quote
Old June 25th, 2008, 12:35 AM   #3
ddeadserious
So you have a regular shaped box, but wrapped in fiberglass?
Why? To seal it?
Old June 25th, 2008, 03:35 AM   #4
muddin_wolverine
yeah it was one from walmart i think, stripped off the carpet and wrapped it up, its 100& waterproof. i even pulled the sub after it was underwater to check and the inside was totally dry. its basically like a fiberglass boat now
Old June 25th, 2008, 08:42 AM   #5
computeruser
computeruser's Avatar
The water issue...it sucks. I suffered through the same concerns with a YJ, but luckily I was able to set the sub box up on a wheelwell, where it was safer. Have you considered spacing the sub up off the floor with a waterproof material? Like taking a trip to BedBath&Beyond and making a couple runners to mount to the bottom of the sub box out of that white plastic cutting board material? Unless you're expecting lots of splashing, this should keep the sub box happy enough.
computeruser is offline   Reply With Quote
Old June 25th, 2008, 09:14 PM   #6
ddeadserious
Yeah, I figured I'd make something to lift it off the floor an inch or two. Thanks.
Any other input on material?
Old June 25th, 2008, 09:17 PM   #7
muddin_wolverine
look online or whatnot for a how-to on fiberglass, alot of people think its harder than it is, as long as its not structural. i learned how from book and a little practice
Old June 26th, 2008, 10:33 AM   #8
PavementPounder
PavementPounder's Avatar
This thread reminds me of a Pontiac resident I saw at a wheel shop with an Impala one winter. He was there gerring some blingy dubs and expensive tires. The rear window of the car was missing and in the back seat there were two kids bundled up like the little brother from A Christmas Story.
Old June 26th, 2008, 05:19 PM   #9
muddin_wolverine
that sounds pretty BAD ASS lmao
Old July 7th, 2008, 06:33 PM   #10
ddeadserious
top
Old July 7th, 2008, 08:19 PM   #11
adamzr2
numero douce undela
adamzr2's Avatar
Hey.... If u go to any marine store they have two part marine fiberglass. I used the lion hair type to fix my jet ski nose. That's the coarses they had but they have fine types. U could buy a can of that it comes with the hardener and mix it up. Pm me if u want some help.
adamzr2 is offline   Reply With Quote
Old July 11th, 2008, 12:18 PM   #12
zanderman90
MTU here I come.
zanderman90's Avatar
Have you looked into doing it in the cubby hole on the cherokee. heres a write up
http://www.jeepforum.com/forum/showthread.php?t=97186
zanderman90 is offline   Reply With Quote
Old July 11th, 2008, 12:23 PM   #13
ddeadserious
Thanks. I've thought about it, but I don't want to deal with all the rattling and sound deadening issues. My Jeep has awful window/door/hatch seals, and nothing is very sealed considering it has little floor left(for now). I'd rather just build a wedge box and remove it when I need to.
I appreciate the suggestion though.
Old July 12th, 2008, 09:26 AM   #14
zanderman90
MTU here I come.
Im still debating between a box or putting it in the cubby.
Page generated in 0.35861 seconds with 65 queries
