Power steering help!!! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 24th, 2008, 02:35 PM   #1
P.O.S.
P.O.S.'s Avatar
Default Power steering help!!!
I know alot of you have done the Chevy V8 swap into your rigs...How did you handle the power steering? I just blew a hole in one of the lines!! Whick port is the feed port in the Jeep box (91 yj)? Could i have the lines switched? Need help ASAP!!!! I have the original jeep box going to a GM pump?
P.O.S. is offline   Reply With Quote
Old June 24th, 2008, 06:10 PM   #2
2kids=nojeepmoney
well, jeep used both gm steering boxes (until the 03 TJ i believe) and pumps through 90.
so there shouldn't be any problem with running a gm engine.
on mine, i used the factory box, the pump for the engine and the factory hoses.
2kids=nojeepmoney is offline   Reply With Quote
Old June 24th, 2008, 08:00 PM   #3
P.O.S.
P.O.S.'s Avatar
do you happen to know which port is the feed? Is it the one closest to the engine? I am afraid that i have them switched.
Page generated in 0.16545 seconds with 32 queries
