D30 Lockrite/Detroit EZ locker install ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 15th, 2005, 11:01 AM   #1
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Default D30 Lockrite/Detroit EZ locker install ?
When installing a Lock rite, Aussie, Detroit ez, etc in a ZJ D30, do you need to remove the ring gear from the carrier to get the cross shaft out? Just curious, before we tear into this on Monday. I know obviously I'll find out when the carrier comes out, but just wanted a brief heads up first. I know on some axles with certain gears, you need to remove the ring gear.
Oh I have 4.56's in my D30
Old November 15th, 2005, 12:35 PM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Mike, yes you will have to remove the ring gear. Remember to clean the bolts & bolt holes out with brake clean. And use red lock-tite on them 50 ft lbs.
Old November 15th, 2005, 01:50 PM   #3
Roadhouse
DrivewayJeeper
Roadhouse's Avatar
Thanks Bill, I believe my bearing kit comes with new ring gear bolts...might just put new ones in, cause I have them.
Page generated in 0.20945 seconds with 32 queries
