Ring and Pinion Question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 22nd, 2008, 12:31 AM   #1
ROADBLOCK
ROADBLOCK's Avatar
Default Ring and Pinion Question
ive got an 88 F150, 4x4, 5-speed 300ci 4.9L inline 6. the ring and pinion went out in the rear end and i dont know what the ratio is to order a new one. anybody have any idea what the ratio would be? 8.8 rear end. im thinking 373's but im not sure.
ROADBLOCK is offline   Reply With Quote
Old June 22nd, 2008, 07:00 AM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
pull the cover and count teeth. divide ring gear teeth by pinion teeth and thats your ratio.
Old June 22nd, 2008, 03:07 PM   #3
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Actually it should have the ratio stamped on the ring gear itself somewhere between the teeth and the mounting surface. Just another way to check. Kodiak450r's method is also good and fairly fool proof. I'm imagining the tag is all but completely disappeared being it's an 88...
Old June 22nd, 2008, 03:09 PM   #4
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
shouldnt there also be a door code?
Bronco351 is offline   Reply With Quote
Old June 23rd, 2008, 12:24 PM   #5
mooseracing
Stuck like a MoFo
mooseracing's Avatar
Send a message via AIM to mooseracing
Yep
Also more than likely 3.55's ....Pull it apart and count
mooseracing is offline   Reply With Quote
Old June 23rd, 2008, 04:44 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Axle tag?
Page generated in 0.28370 seconds with 41 queries
