2001 zr2 pickup not starting - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 20th, 2008, 09:30 PM   #1
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
Default 2001 zr2 pickup not starting
i just put a new fuel pump into a 2001 zr2 pickup that ran before i put the pump in. after i bolted the pump into the truck and hooked it all up the truck wont start. it has furl to the rail, and its got spark. the timing should be right. it has new cap rotor, plugs wires and fuel filter. the only thing i can think of is that is has no injector pulse. any help would be awesome, is there an enertia switch that would shut the fuel off? where are the relays for the injectors?
muddywater is offline   Reply With Quote
Old June 21st, 2008, 12:21 AM   #2
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
the inertia switch is a no thats a ford thing. as for the relay it should be in the under hood relay comparment. but that would only be half of it because, the computer controlls the pulse width and trim through the ground side in the comp. and as for the timeing even though it has a distributor you cant ajust the timeing the comp dose it, you can move the distrubutor but it dose nothing.
beaterk5 is offline   Reply With Quote
Old July 3rd, 2008, 07:02 PM   #3
hobbyjeep
Ok... I had same problem because the NAPA store gave me the wrong pump. You need to check rail pressure... getting fuel is not enough, it needs to be at a 50(?) psi. You need to check spec., but pump assy I got from NAPA only put out about 35 psi and it wouldn't fire injector.
hobbyjeep is offline   Reply With Quote
Old July 15th, 2008, 10:34 PM   #4
blownexploder94
Todd
blownexploder94's Avatar
fuel pressure on it is 55-61 psi
Old August 21st, 2008, 09:59 AM   #5
AWK
AWK's Avatar
are you sure your not having a security issue? Try turning key to the run position, leave it there for more then ten minutes, then with out turn the key back to off try starting it (Do not turn key back to the off position, before trying to start or you will have to try over again).
AWK is offline   Reply With Quote
Page generated in 0.21946 seconds with 38 queries
