96 f150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 18th, 2008, 11:25 AM   #1
sandunein
Default 96 f150
hi everyone. i am looking to put a lift on my 96 f150. i want to put on a 6 inch and 35s, but im worried about not being able to turn the tires. probably wont be off roading till i get a new ring and pinion but will my truck with the 300 straight six and stock gearing turn the tires ok or should i just go with the 4 inch lift.
sandunein is offline   Reply With Quote
Old June 18th, 2008, 11:47 AM   #2
broncobuddha
Starting over
broncobuddha's Avatar
Send a message via AIM to broncobuddha
you running an auto or stick? 4 or 6 inch lift wont really make any difference as far as turning the tires, it will be doggy with stock gears, but how bad depends on the actual stock ratio and the tranny your running
broncobuddha is offline   Reply With Quote
Old June 18th, 2008, 11:55 AM   #3
Lemur
i don't much care for you
Lemur's Avatar
we just put a 6 inch and 35's on my buddies 92 and everything is doing just fine. that is with a balls out race tuned 351 windsor
Lemur is offline   Reply With Quote
Old June 19th, 2008, 05:31 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
I ran a 1989 F150 with the 300 I6 and 36-14.50 tires for quite awhile with the stock gearing (can't remember if it was 3.55 or 3.73) before I upgraded to 4.56 gears.
Just my $.02....
Page generated in 0.23287 seconds with 35 queries
