05 f-250 auto locking hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2008, 03:31 PM   #1
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Default 05 f-250 auto locking hubs
does anyone know if anyone makes an aftermarket set for these...dealership wants $200 a piece and its only the part you turn that went bad?
Old June 19th, 2008, 06:16 PM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Warn, Mile Marker, Superwinch....
Old June 24th, 2008, 09:06 AM   #3
bj house
bj house's Avatar
I just pulled mine off when I did my brakes last week . One very easy snap ring and I just sprayed PB blaster in the back side left it upside down for an hour and worked it a few times :)
just curious anyone care to explain to me how the "auto" feature works without vacuum? I have the Auto/Manual hubs on my 02
Old June 24th, 2008, 11:00 AM   #4
Jeeperz Creeperz
GL 4x4 Vendors
You should have a vacuum line going to the knuckle.
Old June 25th, 2008, 09:23 PM   #5
bj house
bj house's Avatar
hmm I saw a line for the aBS sensor but that was about it.
Old June 25th, 2008, 09:33 PM   #6
bigcountrysg
Countryboy
bigcountrysg's Avatar
The autolocking works by vaccuum. The vaccuum pump is located on the Passenger side wheel well in the engine compartment. It is electric vaccuum pump. It also supplies the vaccuum for the Air control for the vents inside the cab.
Usually when your auto locking hubs stop working. It is from the hub seal. You will have to remove the hub, wheelbearing assembly to replace this seal. A syptom is when you engage the 4wheeldrive the hubs don't lock. If you have the a/c on or the heat vent on it goes to defrost when you engage 4wheeldrive.
Warn, Mile Marker, both make replacement hubs for these trucks. But they do not have the auto locking feature. They are the old style lock and unlock manual hubs.
bigcountrysg is offline   Reply With Quote
Old June 25th, 2008, 09:34 PM   #7
bigcountrysg
Countryboy
Take the hub apart clean it, lube it and put it back together. Unless it actually broke. But I never seen one break. I see them get frozed up. I clean mine every time I do my brakes.
Old June 26th, 2008, 08:33 AM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Should be a little nipple sticking out the front side of the knuckle.
Perhaps you don't really have auto-locking hubs?
Old June 26th, 2008, 11:05 AM   #9
bronco91shee
bronco91shee's Avatar
well working at the dealership for a few years on these trucks....i try to tell all the guys i know to d the obvious...just lock them in manually every few weeks. all it takes to to cycle them every once in awhile. and certainly if you do your own work, lube them every time you do brakes or anything....sometimes you can have a stuck one come back if you soak it in a bottle of sumthing for a few days...i have brought a few back this way that the customer could not afford to replace. other than that, yes there are plenty of aftermarkets.
and it is a vaccum system, if the line is not running down, pulling vaccum or your 3 seals inside are not any good, you wont engage. if you take the kunckle off, just plan on doing all three seals( the axle, vaccum and th oring-yellow.) any ford parts will know exactly which 3 you need, b/c techs replace them as a set every time. also, the chances of getting the big seal on the axle correctly without the special tool is not good. bring the axle in when you buy the parts, slip the tech a 5 spot to put it on for you. i cannot tell you how many customers i have seen come back with a new destroyed seal...feel bad for them, but inform them i have to do it to make it right. also on reassembly, there is a plastic washer with slots in it. make sure the slots are facing in, adn if you would like we usually make th slots a lil bigger so you get better vaccum thru it...
hope this helps, i know these hubs cause alot of problems, but its usually due to lack of maintance or cycling of the hubs
bronco91shee is offline   Reply With Quote
Page generated in 0.38562 seconds with 50 queries
