Brake Caliper Brackets, 14 Bolt, $45 with the discount! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old June 13th, 2008, 12:31 AM   #1
Gravel Maker
Steel Hauler
Gravel Maker's Avatar
Arrow Brake Caliper Brackets, 14 Bolt, $45 with the discount!
Just wanted to make sure you knew about our Caliper Brackets at RuffStuff Specialties.
Single Rear Wheel Bracket
Cab & Chassis Bracket
Our Brackets are sweet and simple, NO Spacers! Nothing welded on! Those are just something else to come loose. Our Caliper Brackets are all made of .375 A50 Plate and bent where required. Every Automotive manufacturer has been bending them for the last 50 years.
By getting away from spacers and extra long bolts we can make a stronger bracket that cost us less to produce and we can sell for less to you. These Brackets are $50 a pair before the GL4X4 discount, thats not on sale, thats the normal price, with the discount it's only $45.
Check us out! We have 11 other Caliper Brackets now and are adding 5 more asap! We have been making these like this for 2 1/2 years and these have the same guarantee as the rest of our products, if you don't like it we'll take it back. Over 4000 pair in use!
[SIGPIC][/SIGPIC]
Dan Fredrickson
www.ruffstuffspecialties.com
916.600.1945
Your Fabrication Parts Source
The New Industry Standard!
Gravel Maker is offline   Reply With Quote
Old January 4th, 2009, 12:03 PM   #2
Gravel Maker
Steel Hauler
Default Yes, we are the guys that make these!
And have for 3 years! Bent is better!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 19th, 2009, 10:02 AM   #3
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
what year calipers do they take? also do you know where i can get a caliper for them that has an ebrake?
nate4d is offline   Reply With Quote
Old January 19th, 2009, 10:23 AM   #4
Gravel Maker
Steel Hauler
Default They use the '73-87.....
Chevy 4x4 3/4 ton 4x4 front rotors & calipers. The '76-77 El Dorado calipers have an ebrake and they do fit, after '77 they changed to the 5.5" caliper pin pattern.
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old January 19th, 2009, 07:24 PM   #5
hollyhellrazor
do you make them for a 98 wrangler d44
hollyhellrazor is offline   Reply With Quote
Old January 20th, 2009, 11:57 PM   #6
Gravel Maker
Steel Hauler
Default Not yet.....
But I have a new guy that started at the first of the year and all he does is design and testing, we have designed 4 new brackets in his first 4 days! So maybe sooner rather than later!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old February 6th, 2009, 12:55 AM   #7
Gravel Maker
Steel Hauler
Default 2 new brackets.....
Tommorrow or Monday!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Old May 11th, 2009, 10:10 AM   #8
Gravel Maker
Steel Hauler
Default These have continued to be.....
Our number 1 seller, and for good reason!
[SIGPIC][/SIGPIC]
Dan Fredrickson
916.600.1945
Thread Tools
Page generated in 0.30827 seconds with 47 queries
