winding cable onto winch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2008, 09:31 PM   #1
FORDMAN49450
FORDMAN49450's Avatar
Send a message via Yahoo to FORDMAN49450
Default winding cable onto winch
Ok, for some reason I just cant get my cable to wind neatly back onto the drum when I use it. it doesnt seem to want to layer like I want it to, it likes to pile up in one area or another, is there any tips or tricks on doing this? Thanks a bunch in advance.
FORDMAN49450 is offline   Reply With Quote
Old June 11th, 2008, 09:34 PM   #2
Mclovin
"The Situation"
Mclovin's Avatar
keep tension on the end. and use something besides your hand to guide the cable in. if your grloves snag the cable you may not get you hand off the remote quick enough and end up breaking a finger or 5
Old June 11th, 2008, 09:35 PM   #3
Mclovin
"The Situation"
Mclovin's Avatar
or get one of these http://www.knightscan.com/product.htm
Old June 11th, 2008, 09:36 PM   #4
ricmitch
ricmitch's Avatar
get a heavy leather glove, I use a welding glove and let the cable slide thru my grip as I guide on the drum/spool nice and slow and keep some tension on it as you let it slip thru your grip.. dont be in a hurry and be careful. I keep my hand a safe distance from the winch so if it dose snag I have plenty of time to let go of the switch ...
ricmitch is offline   Reply With Quote
Old June 11th, 2008, 09:40 PM   #5
oz97tj
Wasn't this attached?
oz97tj's Avatar
as long as you have the first wrap on correct, just do a straight pull agaisnt a tree or something and it'll pretty much wind itself on.
Old June 12th, 2008, 09:18 PM   #6
Renegade II
Coil springs are for pens
Renegade II's Avatar
Been doing this with good luck for years now; Put tension on the line then use a brass hammer or wood block and tap the spooling line tight against the last full wrap. This has worked well at keeping the cable from digging into the layers during short pulls. Just make sure the hammer or wood is long enough so you don't get your hand caught up in the line/drum.
Old June 13th, 2008, 09:10 AM   #7
MozMan68
Poseur Extraordinaire
MozMan68's Avatar
Just buy a nice winch rope....it actually is better not to spool those neatly!
MozMan68 is offline   Reply With Quote
Page generated in 0.28179 seconds with 44 queries
