92 F150 won't start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2008, 07:37 PM   #1
Familyman
Familyman's Avatar
Default 92 F150 won't start
My 92 sits more often than not. It started running eratically last summer ie high idle at stops and shifting strangely. Then this fall I was running it and it quit the high idle thing but then started chugging so bad I would have to almost pump the gas petal to keep it going. Then it would just cough and take off like normal. Now it won't start at all. Any thoughts?
Before all this it ran great. Lots of power and piss poor mileage
BTW 5.8L E4OD electonic shift T case.
Thanks
Familyman is offline   Reply With Quote
Old June 10th, 2008, 10:29 PM   #2
fordlovinfarmer
CHEAP
fordlovinfarmer's Avatar
Check your MAP sensor or TPS
fordlovinfarmer is offline   Reply With Quote
Old June 11th, 2008, 06:55 AM   #3
Familyman
Familyman's Avatar
TPS I know. MAP? Mass Airflow......?
Todd
Old June 11th, 2008, 09:38 AM   #4
masterbeatty
masterbeatty's Avatar
both are good places to start. i belive a 92 is speed density. at least my 92 bronco was. they didnt go to mass air unless you swapped it or someone swapped it until like 94. when it crankes what does it do? possible fuel pump.
Old June 11th, 2008, 02:55 PM   #5
fordlovinfarmer
CHEAP
MAP- manifold absolute pressure
A manifold absolute pressure sensor (MAP) is one of the sensors used in an internal combustion engine's electronic control system. Engines that use a MAP sensor are typically fuel injected. The manifold absolute pressure sensor provides instantaneous manifold pressure information to the engine's electronic control unit (ECU). This is necessary to calculate air density and determine the engine's air mass flow rate, which in turn is used to calculate the appropriate fuel flow.
Old June 12th, 2008, 10:07 AM   #6
Familyman
Familyman's Avatar
I charged up the battery yesterday, went out, cranked it over and it started right up! shut it down and went out about 3 hours later and wouldn't start. Same old issue. It did not want to shift when I did drive it. Picking up a tps and a map this afternoon. Let's see what happens.
Old June 12th, 2008, 12:42 PM   #7
nate4d
Gnarley Davidson
nate4d's Avatar
Send a message via AIM to nate4d
i had this problem with my 97 150 and it was the fuel filter on the frame.
nate4d is offline   Reply With Quote
Old June 12th, 2008, 02:49 PM   #8
sandguy356
bronco built for fun
sandguy356's Avatar
Did you check the battery out?? Heres why, my '97 F250 acted weird like that, turned out the battery had a bad cell. Swapped it out, problem solved.
sandguy356 is offline   Reply With Quote
Old June 12th, 2008, 04:19 PM   #9
firehawk
Live Action!
firehawk's Avatar
Any codes? Probably not if you havent driven in for a few miles.
Old June 12th, 2008, 07:19 PM   #10
Familyman
Familyman's Avatar
TPS corrected the problem. Starts, idles and drives like it did before. Thanks for the help all. BTW what a PITA to get the TPS out. I had to remove the whole butterfly assembly and oops the gasket was ruined! Made a new one traced from the pieces, put it all back together and fired it up!
Old June 12th, 2008, 07:41 PM   #11
fordlovinfarmer
CHEAP
your welcome
Old June 26th, 2008, 12:20 PM   #12
bronco91shee
bronco91shee's Avatar
future thought...if you dont run it much, dont buy much gas. it could gum up, plug the filter when you do run it. change the filter yearly as well. this may help solve future issues if oyu dont run it much...like once every few months. other than that i woudnt worry to much.
bronco91shee is offline   Reply With Quote
Page generated in 0.27830 seconds with 59 queries
