Paint Recommendations - Where to Buy, Type, Amount? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2008, 11:19 AM   #1
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
Default Paint Recommendations - Where to Buy, Type, Amount?
I need to paint (2) steel fenders and a steel Hood off of a Jeep CJ7.
*Any suggestions on what type of paint I should use? (Enamel, Acrylic, etc.).
*How much I will need for these items (Pint, Quart, Gallon)?
*Clearcoat or topcoat recommendations?
*Where is a good paint supplier in Genesee County/Northern Oakland county area?
"It's better to burnout than to fade away!"
MT-Dawg is offline   Reply With Quote
Old June 10th, 2008, 11:22 PM   #2
Stone
Ultimate Mall Wheeler
Stone's Avatar
Send a message via AIM to Stone
Depends on how much work you want to put in them. If not much I would recommend the acrylic enamel from PPG. With this you mix the reducer, paint, and hardener all in one. This gives a decent sheen and you don't put a clear coat. I don't know if that can be sanded and polished though. If your looking for much nicer(more work) paint then they have an acrylic urethane I think they call it that you mix with reducer then put a clear coat afterward you can then wet sand and polish the clearcoat to a show finish. Those are the only two that I've ever sprayed. Also be sure to do all the right prep work for any paint. I found out the hard way. I took some shortcuts on the hood and now its starting to peel at some stress points. Sucks especaily after spending tons of time wetsanding and polishing.
I don't know of any place in Flint. I get mine at westside paint in Bay City.
To paint this jeep.
<---- I bought 1 gallon of the AU (2 gallons sprayable mixes 1:1 with reducer) and it took 3 quarts of the one gallon to spray everything including two sets of doors.
Stone is offline   Reply With Quote
Old June 11th, 2008, 06:16 AM   #3
rustcharger
dubs ain't sh*t
rustcharger's Avatar
I'd go with a urethane if it were me just cause it will last longer. PPG's Omni has the most reasonable price of course there is more expensive stuff out there as well....... If you are dealing with a solid color a single stage urethane would save you the time and expense of having to topcoat your color coat. You're gonna want around 1/2 gallon of sprayable material-that will give you some extra material in case you make a mistake and have to reshoot.
the only dedicated autobody supplier left in Flint is Painter's Supply and Equipment on Richfield east of Dort. I've also heard secondhand the carquest on Fenton rd. south of Bristol carries paint supplies.
rustcharger is offline   Reply With Quote
Old June 11th, 2008, 06:19 AM   #4
steveo
In the band!
rustoleum, enamel, tractor supply, 27 a gallon.
Old June 11th, 2008, 06:26 AM   #5
JEEPR
Playing Possum
JEEPR's Avatar
I use acrylic enamel. I prefer to shoot once and not have to deal with clearcoat. I would say a quart of paint would be plenty for a hood and 2 fenders.
JEEPR is offline   Reply With Quote
Old June 11th, 2008, 11:16 AM   #6
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
Thanks for the advice. I'll stop by the places in Flint and check pricing and availabilty to make my final decision.
The final bridge I have to burn is the color. The fiberglass body and steel doors are already painted a dark shade of Purple (I know, I know, the jokes are never ending about the Purple Jeep). I have a sample for the paint supplier to match, but I know its not gonna be a perfect match. If figure a little mud on the Jeep after I'm done will do the trick.
Old June 11th, 2008, 11:27 AM   #7
stinkpickle
bitter clinger
stinkpickle's Avatar
I used sherwin williams auto paint. You use a reducer with the paint and Its a coupla coats only. no clear coat. I got a beutiful "professional" look that was my first paint job ever. Just remember prep is every thing.
stinkpickle is offline   Reply With Quote
Old June 11th, 2008, 11:45 AM   #8
dodger889
dodger889's Avatar
There is a paint out there that you put on with a roller in very thin coats that looks like a million dollars. wished I knew where I saw it on the web.
Old June 11th, 2008, 11:48 AM   #9
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
So far I have preped the metal by sanding the rust, using Rust Mort, then feathering a few pits with some Bondo. Its a real lite Bondo covering, just to fill the rust pits. Then I have primered the hood and wet sanded. I'm not a body/paint guy so if there is something else to preping I am open to suggestions.
Old June 12th, 2008, 09:09 AM   #10
dodger889
dodger889's Avatar
Ok found the link I read some time ago
http://www.rickwrench.com/index79mas...llarpaint.html
http://board.moparts.org/ubbthreads/...0&fpart=1&vc=1
Something you might try for a cheap paint job and lots of work....
Old June 12th, 2008, 11:53 AM   #11
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
Thanks for the link...wow that sounds like a lot of work. But $50 is cheap!
Old June 14th, 2008, 01:44 PM   #12
Stone
Stone's Avatar
Did you strip the old paint? If not did you at least use wax and grease stripper on the paint before the primer? Your going to want to use sealer on the primer before any paint. And remember if there is any rust left under the paint it will be back. Its just a matter of time.
Old June 15th, 2008, 06:13 PM   #13
MT-Dawg
Camel Buggy
MT-Dawg's Avatar
I used the hand grinder to get all the rust spots. Then I took some scotch bright to all the painted surfaces. Then I washed the fenders with some grease-cutter and water. It was the purple stuff you get from Autozone and mix it with water.
What type of sealer do you recommend? Is it spray on in a can or something else?
Old June 15th, 2008, 06:17 PM   #14
Fraser
Fraser's Avatar
sealer is a 2-part catalyzed mix, at least the stuff i have used is.
Page generated in 0.37145 seconds with 65 queries
