roll bar, full size chevy - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 9th, 2008, 08:22 AM   #1
muddin_wolverine
muddin_wolverine's Avatar
Default roll bar, full size chevy
ok ive been reading for days and ive come up with a design for my truck. its an 87 k10, lifted 9 in, soon to be 13. im not looking for crazy high speed racing protection, just more than enough to keep my cab from turning into a convertable if i ever tip it over. i came up with this awful representation cause autocad isnt working. i hope the pics make sense of what im trying to do. i plan on using square and round tube for the build. also need help deciding what sizes to use for what. if the pic doesnt make sense ill try to translate. any help is apreciated.
the main hoop will be round tube with a big x bracing from coner to corner.
muddin_wolverine is offline   Reply With Quote
Old June 9th, 2008, 09:16 AM   #2
Bones
Bones's Avatar
looks good, but I would probably keep the cage the same width as the body, instead of just the little hoops at the top. It looks like you drew it up that way, and then painted over it with a white line.
and why not do it all in round tube instead of part round, part square?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 9th, 2008, 11:17 PM   #3
muddin_wolverine
ill probably do it that way like i planned at first. the part round part square is just to save money. i know the hoop should be round since thats what most of the weight will be on as it rolls, the rest is just support.
what i really need is help choosing pipe/tube. ive read all the pipe and tube threads but it looks like most of those guys are driving smaller jeeps and such and building complete much stronger cages.
Old June 10th, 2008, 04:37 AM   #4
muddin_wolverine
so far im planning on using 2x2 3/16th square tube. how thick would 2inch 11gauge round tube be?
Old June 10th, 2008, 09:00 AM   #5
muddin_wolverine
buMp
Old June 10th, 2008, 12:46 PM   #6
fsumotorhead
N8KVB
fsumotorhead's Avatar
about the thickness of electrical conduit, maybee a little thicker?
Old June 10th, 2008, 12:48 PM   #7
Bones
Bones's Avatar
thats not tube... that's Pipe. look into 2" .120 wall HREW tube
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old June 10th, 2008, 01:48 PM   #8
kickstand
circling the drain
kickstand's Avatar
using square is not going to save you enough money to justify the ugly its going to add.
Old June 10th, 2008, 06:52 PM   #9
muddin_wolverine
i just priced it out and the 2'' .120 wall HREW (FOR SURE TUBE) will be cheaper than using square/round since theres a bulk discount. thanks for the help guys. ill get pics up in the build section once i start fab. gotta get back from iraq first :)
Page generated in 0.26663 seconds with 51 queries
