97 Tj Lt1 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2008, 07:48 PM   #1
dirkrc51
dirkrc51's Avatar
Default 97 Tj Lt1
I'm about 90% done with the build.
Started out as a 1997 wrangler with 2.5
Pre engine:
3.5 Teraflex lift
Tefaflex front track bar
33x12.5-15 BFG Mud
10" Black Steel rims
4.88 Front and Rear
Rear Lock-rite
Engine swap info:
LT1 out of a 95 Corvette
New main and rod bearings
New oil pump
New intake gasket
New valve cover gasket
New oil pan and gasket
New rear main seal (leaking)
New flexplate
New alternator (old one didn't work)
185 thermostat
Smog and EGR block-offs
"custom" 3.5 intake
Larry's electric stand-alone harness
Reprogramed #16188051 pcm
LT1 PCM piggy backed to stock 2.5 PCM (so the gauges will work)
Transmission:
Rebuilt 700r4
JB conversions adapter to NP231
Teraflex SYE
Lokar Shifter in stock location with stock boot
Action drive shaft
Other Items
M.O.R.E. motor mounts (Highly modified)
1" body lift
Autometer tach/shift light
TCI torque converter lock-up kit
Modified stock skid plate
2 into 1 3" flowmaster
To Do List:
8.8 rear axle (getting parts together)
Stall converter (when I fix rear seal)
Tera low 4:1
Front and Rear Bumpers
Rockers
Long Arm
ID:	26546   Click image for larger version
ID:	26547   Click image for larger version
ID:	26548   Click image for larger version
ID:	26549   Click image for larger version
dirkrc51 is offline   Reply With Quote
Old June 8th, 2008, 07:49 PM   #2
Bronco351
Powered by Ford
Bronco351's Avatar
Send a message via Yahoo to Bronco351
Nice
Bronco351 is offline   Reply With Quote
Old June 9th, 2008, 06:00 AM   #3
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
looks like it was meant for that chassis, keep up the good work!
91 k1500 is offline   Reply With Quote
Old June 9th, 2008, 02:37 PM   #4
robo-3
02 tj
robo-3's Avatar
nice job!
robo-3 is offline   Reply With Quote
Old June 9th, 2008, 04:34 PM   #5
Shaguardriver
I'd wheel it!
Shaguardriver's Avatar
Looks Great
Shaguardriver is offline   Reply With Quote
Old January 22nd, 2010, 07:05 PM   #6
dirkrc51
dirkrc51's Avatar
Done a few upgrades
Different aluminum radiator
Taurus 2 speed fan and shroud (fit very well)
52mm throttle body
Rework air intake
Clean-up some wiring
Wide O2
Transmission temp gauge
Rework governor
M40 rockers
M4O half-doors
Old January 22nd, 2010, 07:08 PM   #7
dreezy
Haggard Fab
dreezy's Avatar
Its amazing how good a fi sbc looks in a wrangler. I wish Chrysler would get the hint.
Old January 22nd, 2010, 07:23 PM   #8
capone
capone's Avatar
Looks Great. Those half doors are Sick!
capone is offline   Reply With Quote
Old January 23rd, 2010, 07:20 AM   #9
Shaguardriver
I'd wheel it!
The Doors look great!!
Page generated in 0.28985 seconds with 51 queries
