hitch - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 8th, 2008, 11:14 AM   #1
93XJcountry
Nothing Runs Like a Deere
93XJcountry's Avatar
Default hitch
would welding a hitch to my frame be just as strong of not stronger than bolting it? if so should i stick weld or mig weld it?
93XJcountry is offline   Reply With Quote
Old June 8th, 2008, 11:21 AM   #2
forbyefore
forbyefore's Avatar
I think they use bolts cause welds can crack the frame when the frame itself twists
forbyefore is offline   Reply With Quote
Old June 8th, 2008, 11:37 AM   #3
93XJcountry
well the most i will be hauling should only be a 18 foot hallmark trailer
Old June 8th, 2008, 12:35 PM   #4
Bones
Bones's Avatar
welding it would be fine. the frame has welds,the hitch has welds... no reason not to weld them together...
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 8th, 2008, 12:51 PM   #5
All depends on the quality of the welds. If the welder is not an experienced at overhead welds, I would go with grade 8 bolts. With the bolts, you know the integreity. With the welds you don't.
Not to be a jerk, but if you don't know which type of welder to use, it is an indication that you are not very experienced with welding. Leads me to say don't take a chance.
Old June 8th, 2008, 12:56 PM   #6
blownexploder94
Todd
blownexploder94's Avatar
i would say just to bolt it to the frame.. there is always a chance of it cracking or breaking a weld.... or if you sell the truck with it welded and it breaks..... don;t take a chance of putting other people in harms way if something was to break..
Old June 8th, 2008, 01:54 PM   #7
93XJcountry
it all depends on what i have access to. i would preffer to weld using a mig welder
Old June 8th, 2008, 02:02 PM   #8
blownexploder94
Todd
a mig welder would not be very good to weld a hitch to a frame.... use a stick if you are absolutly set on welding it
Old June 8th, 2008, 02:02 PM   #9
93XJcountry
ok, what rod should i use?
Old June 8th, 2008, 02:05 PM   #10
Freak
Wheelin the HD
Freak's Avatar
Why are cross members riveted or bolted on then?
the frame flexes every time you take off and every time you hit a bump its not about the weight of what you are towing, its just plain and simple what a vehicle does.
i would say bolt it, it took 20 minutes to assemble my hitch, drill the holes, and bolt it on, wont it take roughly the same ammount of time to weld it?
Old June 8th, 2008, 02:07 PM   #11
blownexploder94
Todd
thats what i said above... i don;t think i would ever weld a hitch to a frame just because of the what if's can happen . like it breaks going down the road and hits the family mini van near you, not a good thing....i was just saying if you absolutly are set on welding a hitch to a frame don;t use a mig
Old June 8th, 2008, 02:49 PM   #12
why?
Old June 8th, 2008, 02:52 PM   #13
trogdor the burninator
Insert Comment Here.
trogdor the burninator's Avatar
Send a message via AIM to trogdor the burninator Send a message via MSN to trogdor the burninator
FLUX CORE!
sorry, joke from work.
Just another disgruntled OIF vet.
trogdor the burninator is offline   Reply With Quote
Old June 8th, 2008, 02:55 PM   #14
blownexploder94
Todd
just because i have been told that when you weld heavy steel of thick to use the stick welder over the mig... I could be wrong though, im not saying im 100% correct. but when they do weld thick stuff like say backhoe buckets and such they use stick .... correct me if im wrong though or teach me something i don;t know
Old June 8th, 2008, 03:54 PM   #15
93XJcountry
Originally Posted by trogdor the burninator View Post
FLUX CORE!
i do have access to flux core.
Old June 8th, 2008, 03:59 PM   #16
ddeadserious
ddeadserious's Avatar
MIG can weld things just as thick as a stick welder. It's just that a MIG machine that can do real thick stuff is relatively expensive.
Just bolt it on though, there's no reason to weld it. The rest of the world uses bolt on hitches and they seem to work just fine, why change something that doesn't need to be changed?
ddeadserious is offline   Reply With Quote
Old June 8th, 2008, 04:03 PM   #17
93XJcountry
why change? 1. don't have a drill powerful enough to drill through frame, 2. i bought one off of a truck like mine but ext cab and the holes didn't match and it was about 1 quarter of an inch to wide on each side. but if anyone has a hitch that will work on a 1991 ford f-150 4x4 single cab short box for cheap let me know.
Old June 8th, 2008, 04:12 PM   #18
MiNi Beast
MiNi Beast's Avatar
Now I kinda have the same question, except I popped out the bolts through the frame so was wondering about just welding it back up, I use it to haul my utility trailer but mostly as my real recovery point. This happened yesterday at the charity run...
Old June 8th, 2008, 09:24 PM   #19
ddeadserious
Wow mini beast, that's rough.
I'd get a 2" strip of 3/16" flat stock and weld that up to the bottom of the frame rail real good(that area clearly needs to be repaired), and then bolt the hitch to your fresh steel.
Old June 8th, 2008, 09:32 PM   #20
Toivo
Feel lucky?
Toivo's Avatar
please don't weld it.
If you don't know what stuff to use, you don't possess enough welding skills to keep that hitch/trailer attached to your truck and you'll probably kill someone.
Kthanks.
Page generated in 0.56357 seconds with 83 queries
