207 vs 231 t-case - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 09:41 PM   #1
jbsjunk
Little Member
jbsjunk's Avatar
Default 207 vs 231 t-case
I'm in the middle of my small block XJ build and currently have a 207 case in it, but I have the option of going to the 231. The 207 has a mech speedo and the 231 has electronic. Is there much strength difference between the two, both being S-10 cases? Will the SYE kits for the 231 work in the 207? I know hack and tap is a option here. I know the output shaft is the same, spline count anyway because the yoke works in both.
I would like to keep the mech speedo. If I keep the 207, more than likely I'll swap a new chain in it.
Opinions on the matter? Is the strength difference enough to even worry about?
Old June 12th, 2008, 11:51 AM   #2
2kids=nojeepmoney
swap to a 231. the early ones came with mech. speedos and the senders just swap out.
2kids=nojeepmoney is offline   Reply With Quote
Page generated in 0.16615 seconds with 29 queries
