coolant or water for cooling?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 09:17 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default coolant or water for cooling??
Whats better to run if the engine runs hot??
Straight water?
Water with the water wetter additive?
Coolant at 50/50 mix?
or coolant at some other mix??
Old June 7th, 2008, 09:27 PM   #2
Mud'N'Truck
I'll Finsh One, One Day
Mud'N'Truck's Avatar
Water runs coolest, but not as good for the interals as regular antifreeze. If your willing to flush it every winter id go water with a additive.
Old June 7th, 2008, 09:57 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Yeah i know it will corrode the block/heads. I may just run 50/50 and add some additive.
Shit runs hot and silver lake is friday
Old June 7th, 2008, 10:13 PM   #4
Sandals
Fucking Zen as Shit
Sandals's Avatar
50/50 with some water wetter, and make sure you dont have any air bubbles
Old June 7th, 2008, 10:31 PM   #5
Mud'N'Truck
If you want to bring it out to my house some time this week i can help you bleed it all out. I have a special coolant bleeder i bought for work.
By adding the additive its supposed to make it alot less corrosive if your running water. Id try the water and additive. Cheaper then buying coolant and supposed to work better for summer. I didnt do it just cuz i didnt want to worry bout a surprize cold day or somthing
Old June 7th, 2008, 10:32 PM   #6
Mud'N'Truck
What you running for fans?
Old June 7th, 2008, 10:46 PM   #7
GetItOffroadGMC
GetItOffroadGMC's Avatar
Cold days are a hard lesson. I learned on T-day. But it does run cooler.
GetItOffroadGMC is offline   Reply With Quote
Old June 8th, 2008, 01:18 AM   #8
Mclovin
"The Situation"
Mclovin's Avatar
put a big ass radiator on that bitch with a tarus fan it'll keep cool but for now run water
Old June 8th, 2008, 09:33 PM   #9
phazer42
I wheel, therefore I am
phazer42's Avatar
if yer runnin hot, you can pull the t-stat for additional flow and / or increase the radiator size..... for the one time you forget to pull the water out, I would just run a mix..... engines aren't cheap nor easy to replace....
phazer42 is offline   Reply With Quote
Old June 8th, 2008, 09:45 PM   #10
redleg
Coolant (glycol) is designed to dissipate heat. It also lubricates your pump. I was researching for antiifreeze additives for the water in my boiler stove and learned there is at least a 20% loss of BTU's when useing water mixed with glycol. It's a good antifreeze AND coolant, but bad for the use I was intending. So I would say much better than straight water, unless you think you'll cook the motor soon anyway, then a waste of money.
redleg is offline   Reply With Quote
Old June 9th, 2008, 09:48 AM   #11
fsumotorhead
N8KVB
fsumotorhead's Avatar
No t-stats usually result in an overheat, water circulates too fast to and there isn't enough heat rejection through the radiator
70% water
30% coolant
is the most effient mix
Old June 9th, 2008, 04:27 PM   #12
pyrowaves
The Boss
pyrowaves's Avatar
Send a message via AIM to pyrowaves
70% water
30% coolant
is the most efficient(fixed) mix
x2
pyrowaves is offline   Reply With Quote
Old June 9th, 2008, 05:55 PM   #13
phazer42
phazer42's Avatar
all a t-stat is a restriction in the line to hold back pressure to allow the engine to warm up more efficiently.... when I was racing late-models we would often take the t-stats out because we didn't care how engine ran when it was cold as it never took long to heat it up.... we ran many many laps, hard, without a t-stat (2 seasons worth and we finshed in the top 5 both seasons).... of course when we are racing, glycol isn't allowed, so we were running straight H20......
perhaps if you are having troubles with a t-stat removed your radiator is undersized..... just a thought.....
Old June 9th, 2008, 06:05 PM   #14
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
alunimun radiator griffen thats not undersized. Fan works great. I think it was the restriction in the exhaust. 1/2" hole to connect the exhaust to the Y in a 3" pipe...... yeah not so sweet.
Old June 10th, 2008, 11:40 AM   #15
fsumotorhead
N8KVB
Automotive radiators are all undersized, because of the load factors involved. It isn't until you get a "performance" or specialty radiator that they are sized more appropriately, so in your case you are probably right about it offering enough capacity
Old June 10th, 2008, 12:04 PM   #16
chizzel21
SWAMPBUCKS OFFROAD
chizzel21's Avatar
Water With Water Wetter
chizzel21 is offline   Reply With Quote
Page generated in 0.33463 seconds with 71 queries
