blowing seals, alot of them - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 07:13 PM   #1
muddin_wolverine
muddin_wolverine's Avatar
Default blowing seals, alot of them
ive got a 383 ina 70s block with a performer high rise intake with high press/vol oil pump and i keep blowing the front and rear intake gaskets out, like completely hanging out out. how do i fix this? are there rubber on metal ones i can buy somewere? i cant seem to find anywere that sells individual high performance gaskets. and i dont wanna buy a whole kit for 2-300$. ive tried rtv on paper and rtv on rubber, even the ones with the little tabs that stick into the holes in the block. ive changed them 4 times
muddin_wolverine is offline   Reply With Quote
Old June 7th, 2008, 07:17 PM   #2
Hunter9
Not Right!
Hunter9's Avatar
Sounds like you have another issue. Was the block decked or the heads milled, if so how much?
Also are you having any other issues with oil consumption, blow-by, oil leaks elsewhere, etc?
Hunter9 is offline   Reply With Quote
Old June 7th, 2008, 07:23 PM   #3
muddin_wolverine
decked the block to flat, ended up being .02 off the top and sides, heads are flat, intake is square. i made sure nothing was warped and such after the 2nd seal blew out, and i use a torque wrench :) its the only problem im having, everything else is peachy
Old June 7th, 2008, 10:53 PM   #4
s.hembree
s.hembree's Avatar
Throw the end seals away. Just use a bead of ultra black or ultra grey rtv. Let it fully set up before you fire it up. The better gasket sets don't even come with the end seals anymore...
Old June 7th, 2008, 11:00 PM   #5
muddin_wolverine
ill try that and see how it works
Old June 7th, 2008, 11:22 PM   #6
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
x2. i never use end seals as no matter what you do they leak or blow out. RTV is a dead cure for your problem. if you blow out RTV then you have some serious crankcase pressure building up.
Old June 8th, 2008, 12:14 AM   #7
merr6267
More boost than yours:)
merr6267's Avatar
Yep, lay a bead just taller than what the gap would be on top of the end rails. Let it 'skin' and smear a little on the intake side to stick to. Then drop it on. Letting is set up just a little before plopping the intake on prevents it from spooging all over and then into your valley.
Also like they said, make sure you have enough crankcase ventilation. If you're developing pressure there you need to vent it. A high horse engine will need more venting than stock, depending on a lot of other factors.
merr6267 is offline   Reply With Quote
Old June 8th, 2008, 11:36 PM   #8
elcaminokid
elcaminokid's Avatar
sound like they got you on the right track throw out the gaskets and use rtv instead
elcaminokid is offline   Reply With Quote
Old June 9th, 2008, 12:21 PM   #9
revho
$9.00 vanilla malt
revho's Avatar
The title of this thread is extremely misleading.
revho is offline   Reply With Quote
Old June 9th, 2008, 07:49 PM   #10
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
"I swear - it's just ice cream!"
@clarkstoncracker
Old June 9th, 2008, 09:39 PM   #11
merr6267
merr6267's Avatar
lolz
Old August 14th, 2008, 12:35 PM   #12
DodgeitRamit
DodgeitRamit's Avatar
The "great stuff" sealer is awesome, a little more expensive but its the best stuff I have ever used
DodgeitRamit is offline   Reply With Quote
Old August 22nd, 2008, 10:21 AM   #13
kevinr839
kevinr839's Avatar
It is called THE RIGHT STUFF it is made by permatex. It is all I use anymore especially when working on rear axles and intake end seals. It is about $18.00 for a can of it but it is worth the money.
kevinr839 is offline   Reply With Quote
Old August 22nd, 2008, 10:44 AM   #14
cruzer72
cruzer72's Avatar
X2 , I added exhaust evacts to my 406ci. that helped alot.
cruzer72 is offline   Reply With Quote
Old August 22nd, 2008, 04:59 PM   #15
junk90xj
ALLPRO AUTO
junk90xj's Avatar
agreed best sealer ive used so far.
http://www.apalansing.com/
Old August 25th, 2008, 06:12 PM   #16
2kids=nojeepmoney
you should be fine with seals, but if you're blowing them out that fast, you're building up pressure in the crankcase. either you don't have a PCV and breather, or you hooked it to ported vacuum.
2kids=nojeepmoney is offline   Reply With Quote
Tags
"that's just ice cream"
Page generated in 0.37965 seconds with 71 queries
