CB Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 7th, 2008, 06:17 PM   #1
Covert_Ops
Default CB Help
Okay here is the skinny....
Just installed my /CB antenna, powered up, drove to the highway/truck stop, and could not get anyone.
I know they suggest that you tune the antenna, but shouldn't I get something?
The antenna is grounded to the frame.
Anyone in the Ann Arbor area that could help me tune it?
Covert_Ops is offline   Reply With Quote
Old June 7th, 2008, 07:30 PM   #2
phazer42
I wheel, therefore I am
phazer42's Avatar
you need to use a SWR meter and get the antenna matched with your CB... this will require you to probably shorten your antenna length by a few millimeters.... I had a guy at radio shack do it for me.... but you will also need a set of bolt cutters to really get a clean cut on the antenna...
if you don't have them matched, you can and likely will, damage your CB.....
phazer42 is offline   Reply With Quote
Old June 7th, 2008, 07:35 PM   #3
Chip Wheeler
Chip Wheeler's Avatar
It's probably not hooked up correctly. Hancho and I learned that lesson last week. Plus tuning it will help a lot.
What type of antenna is it?
Chip Wheeler is offline   Reply With Quote
Old June 7th, 2008, 07:43 PM   #4
TS-Off-Road
989-832-4999
TS-Off-Road's Avatar
"The antenna is grounded to the frame."
That's your problem
TS-Off-Road is offline   Reply With Quote
Old June 7th, 2008, 07:45 PM   #5
Covert_Ops
Firestick antenna...
Why is the frame grounding bad?
Old June 7th, 2008, 07:59 PM   #6
Axe Lip
Go Lions
Axe Lip's Avatar
what do you have the squelch set at turn it down until u hear fuz then just back far enough for it to go clean
Axe Lip is offline   Reply With Quote
Old June 7th, 2008, 08:16 PM   #7
Axe Lip
Go Lions
Axe Lip's Avatar
did you have it to search or on channel 19?
Old June 7th, 2008, 08:20 PM   #8
Covert_Ops
Yeah... Got the squelch thing down....
I tried on 19 and search.
Old June 7th, 2008, 08:31 PM   #9
Chip Wheeler
Does the plastic bushing go into the hole you drilled into the bumper? That and the paint being scratched off to make a good ground is very important.
I would start there and then try and find someone to tune it.
Old June 7th, 2008, 08:45 PM   #10
Freak
Wheelin the HD
Freak's Avatar
what kinda CB do you have? is the mic hooked up? I made a couple mistakes when I hooked mine up (had a nob adjusted wrong so I could only hear someone right next to me). you don't tune a antenna with bolt cutters, use sand paper or a file on a fiberglass antenna, the guy that did my frances used a dremil with a sanding wheel.
Old June 7th, 2008, 08:46 PM   #11
Covert_Ops
scratched paint with a wire brush at the bolt on the frame. I have one of those cool tech LLC antenna deals that mounts in the lic. plate housing.
Old June 7th, 2008, 08:49 PM   #12
Covert_Ops
[QUOTE=Freak;1140732]what kinda CB do you have? QUOTE]
I have a midland... all in one kind of thing Midland 75-822
It works fine when I have the small antenna on it and not the new full antenna.
Old June 7th, 2008, 09:04 PM   #13
Freak
Wheelin the HD
Freak's Avatar
thats an interusting radio, not sure what the issue is, what kinda vehicle and wheres the antenna mounted? someone on here was having problems because the antenna wasn't taller than the roof. whats the resistance on the cable coming from the antenna?
Old June 8th, 2008, 07:23 AM   #14
Covert_Ops
2007 JK Unlimited... Mounted in the lic. plate housing (cool tech llc kit)... I do not know the resistance of the cable. How would I find that out? antenna is taller than roof.
It is a tunable antenna... Would i need to file / grind it off, or would there be some kind of adjustment on the antenna itself?
Old June 8th, 2008, 08:38 AM   #15
jcs5275
jcs5275's Avatar
Have you check to see if the coax cable is not broken?
jcs5275 is offline   Reply With Quote
Old June 8th, 2008, 08:44 AM   #16
Covert_Ops
How would I know if the coax was broken?
UPDATE: I took the quick disconnect off... traveled to the highway. Heard one very broken up call from someone chatting with someone else. When I did a check, I could not get anyone to confirm my call.
Old June 8th, 2008, 09:09 AM   #17
Chip Wheeler
Take the cap off the top and it has an adjustment screw. Still sounds like it's not grounded properly..........
Old June 8th, 2008, 09:57 AM   #18
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
the mounting hole for a firestick antenna and the firestick firering cable has to be 1/2" you need to make sure that you have the lip of the nylon insert of the firering facing the mounting surface, and the nylon washer on the otherside of the mounting surface to isolate part of the antenna...now the part of the firering cable that does need to touch metal is just outside of the nylon insert ring that has exposed metal, that is the ONLY part of the whole system that should touch metal...try that, oh and go get it tuned by someone with a meter
Old June 10th, 2008, 03:37 PM   #19
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
screw firesux antennas. buy a quality top load tuneable fiberglass whip like a skipshooter.
I have ran a 7' s.s. on my YJ for many a year.
get a swr meter. make sure you antenna ground plane is correct (not having a short whip that comes up the side of the jeep needs to be above the jeep to get the best possible ground plane.
Page generated in 0.28545 seconds with 80 queries
